Question about Husqvarna Garden
Kohler engine starts but won't continue to run
  • 252 Answers
If this engine is only runs on the choke and stops when its open sounds like a fuel problem !
make sure the carb solenoid is getting 12 volt to open up the main jet
check that the fuel cap is venting ?
check the fuel filter ?
check the fuel pump is causing flow when being cranked
if it has one
check the carby jets and emulsion tubes and air bleeds are clear and needle and seat aure not stuck closed ?
check the valves are opening and closing and they have correct clearance
have a look let me know engine model and spec number
cheers paul
Posted on Sep 04, 2010
Won,t run because breaker points don,t open in Kohler engine
I am guessing you are working on a K model engine because I believe that was the last model to use points. Sometime they arc and weld together and the rod just bends them . This U Tube video is the best way to inform yourself for this repair. How to adjust and set Points Gap on Kohler Engine
May 21, 2016 | Garden
Kohler ch13s will not start{backfires]. But some times after many trys it will start and run find
I had this puzzler too! Turned out the problem is caused by the fuel-bowl needle valve. It may look OK but looks are deceiving. It gets a coating on the tip that causes a poor seal ... poor enough to allow fuel to flood the engine after a short run time. The flooded engine dies, but restarts OK after a delay that clears (cooks off) the excess fuel that flooded/killed the engine. SOLUTION: Remove the needle valve and carefully wipe and clean the tip with a white cloth soaked in solvent (gas is OK). The cloth will show the deposits that cause the problem. Carefully re-install the needle valve and float parts, start the engine, confirm that it runs OK and continuously. Simple fix .... puzzling problem.
Sep 17, 2014 | Kohler Replacement Engine Part Pa-22537...
What is causing my 12hp kohler engine to backfire and quit running when given any throttle?
That sounds like either bad (old) gasoline or the carburetor needs cleaning very badly - it's running very lean.
Jul 19, 2014 | Kohler Engine 12hp Cs Command Horizontal...
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
Kohler 149 cc engine won't start seems to be getting no fuel
This may not fix your problem but it does deal with that engine. I just tried to replace the spark plug in that engine and it took me 5 hours. The Kohler plug in the engine that came from the factory cannot be found in traditional stores and it is a strange size, 11/16 or 12 mm. The Kohler plug is #1413211. I could not find a match in a book. Divine intervention lead me to a place where they were fixing the Kohler 149cc engine that had the same plug in it that mines did. I discovered that a Champion 8815 does fit the engine but it takes a 18mm socket. It did fix the problem and the mower works. Hopefully this will save someone my hassles.
Apr 28, 2012 | Garden
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
313 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
