Question about Brother LS-2125 Mechanical Sewing Machine
Tension doesn't seem to work at all. I cleaned the bobbin cases and the whole machine inside, oiled it, made sure it's threaded correctly--and the tension is still completely messed up. Turning the tension dial doesn't make any difference--the sttich doesn't change regardless of what number it's on. It's very loose.
  • 22,219 Answers
Their is a friction clutch inside tension control ,try taking it apart and cleaning it with some alcohol ,if that doesnt work then dump it and buy a new machine ,as they are often on offer in lidel for 59 euros ,so they are not expensive regardless what country your in
Posted on Aug 26, 2010
Brand new machine, do I need to oil it? singer talent 3321 is suppose to be EASY...needle broke, now it will not sew, seems to be stuck and bobbin seems to not work.
1. You need to remove the bobbin case and adjust the tension. The tension should allow the thread to move with a slight tension. Clean the area with a qtip. The bobbin case sits in a an area that is called the race. The race needs one drop of oil. Replace everything.
2. Replace the needle. Make sure it is in the right direction. Thread the top while the foot is up. If the thread gets stuck while threading there is a problem. The thread should move easily while the foot is up. After you thread the machine except the needle you can put the foot down. Now pull on the thread. It should give you a slight amount of tension. Usually four is a good number. If the tension is too tight you can adjust as needed. Now, thread the needle. Hold the thread under the foot while you turn the hand wheel. The bobbin thread should come up.
3. Give your machine a try with a slow speed.
Mar 25, 2017 | Singer Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
Tension
I'm assuming the thread is looping on the bottom. If this is not the case, ignore the rest of this.
Perform a tension test. Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Aug 02, 2008 | Bernina 1008
Help! Tension Problems
Looping on the top means there is no tension on bottom. The bobbin thread generally rotates counter clockwise. The thread must get under the tension spring. The spring must be adjusted equal to the top tension. This you will have to play with to tighten or loosen as needed. When you sew in a zigzag you might want to loosen the top tension slightly. On a regular basis remove the bobbin case and clean with a qtip. On the race put one drop of sewing machine oil. Clean the bobbin case and replace.
Mar 25, 2017 | Singer 57815 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
20 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
