Question about Dremel 1800-01 Scroll Station 18" Variable Speed
Dremel scroll saw 1800 does not run if I crank up the variable speed switch. I can turn it to about nine o'clock and ten it dies. Replaced the brushes and it did not help.
  • 90 Answers
You should be able to replace the variable speed switch.
Posted on Sep 02, 2010
Dremel 1800 scroll saw manual
Here is a list of what you can get. If it is not listed there then there is a spot at the bottom of the page to request a manual.
Dremel manuals
Aug 22, 2012 | Dremel 1800-01 Scroll Station 18" Variable...
Motor turns a fraction of a turn and stops. I've
With an ohmmeter between the prongs of the power plug and the switch turned on, rotate the motor and watch for a drastic change in the resistance. Theresistance should be fairky low.
IF during the rotation the resistance goes way up, there is a failure of an armature winding.
I notice it says variable speed, so the above may not work. The next plan is to bypass the speed control to see if the problem might be with the control... I suspect that is where the problem is. Bypass the control putting full voltage on the motor an see if it runs. If it does, then speed control has a problem.
Jan 27, 2010 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Breaking blades
You have to use 127 mm pin end blades, and if you apply a side pressure they will keep breaking
May 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel Scroll Station 1800
You need to replace the variable speed control switch. Other than that, your not doing anything wrong. Have fun
Feb 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel 1800-01 Scroll Station 18" Variable Speed Logo
212 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
