I know software that requires key codes and be duplicated so they can be used more than once. how does someone duplicate them
  • josh garrett Aug 27, 2010
    yeah i know thanks for the answer thats not what i asked you. I wasn't looking to do it i was wondering how it was done but since you decided to lecture me on something i already knew i will find out from someone else. Being there is over 6 billion people in this world i am sure someone is going to tell me
  • 4,472 Answers
What key codes are you referring to? In most cases key codes for software CAN NOT be duplicated and is the whole reason they are implemented in the first place.
Thank you,
Lee
Posted on Aug 27, 2010
  • 2,973 Answers
What you are asking for is called Software Piracy in legal terms and is culpable in all countries. Please refrain from it as no one, specially FixYa, will like it. Thankyou.
Can one code another key to work on my car? And if yes how would I know it has happened?
What car do you have. If the car has an anti theft system, I doubt someone could duplicate not only the key teeth, but the correct transponder as well. If it is a regular key someone could have copied your key, and there is no way for you to know this. Unless you know someone who had your keys and the opportunity and motive.
Mar 02, 2018 | Cars & Trucks
Key Duplicated won't open door works with ignition only
Your duplicate key may be a valet key which would not let a parking lot attendant into the trunk or the doors. If you don't have the original master key, you may have to get a locksmith involved. I doubt the dealer would have key codes for a model that old.
Jul 25, 2013 | 1999 Honda Accord
Duplicate file searcher
The software that I have used and recommend compares every important factor that you will need to make the right decision when dealing with duplicates. It finds duplicate songs, emails, files, and more easily on your computer by using a 'Wizard' function for the most common duplicate files and folder finding tasks. It has great customer support, and is the most thorough out of all of the programs that I have tested.
Feb 27, 2013 | Computers & Internet
How to program ct 68a remote
Text from manual below. Pictures of manual attached.
TO"LEARN" A FIX CODE PROGRAM FROM ANOTHER UNIT:
1. Press and hold both buttons (1 & 2) on the SPR. The LED will flash three times. Keep holding {for about five
seconds) until the LED flashes again (twice), indicating that it's ready to duplicate your garage door opener's
code. Release both buttons (Fig. 1 ).
2. Place your existing garage door remote and the SPR unit within an inch of each other. Press and hold the
first button on the existing unit while pressing button 1 on the SPR unit. The LED will flash, indicating that it
is learning. Keep holding the buttons until the LED light goes out. At this point, the SPR unit has duplicated
the code (Fig. 2).
3. Follow Step 2 to duplicate another code.
4. Exit the learning mode after duplicating codes by pressing and holding both buttons on the SPR unit. The
LED will flash once to indicate that you have exited learning mode. Examine the unit to see if your codes
were duplicated completely.
TO EXAMINE CODES:
If the remote is programmed correctly, the LED stays lit while the button is pressed.
If code duplication has failed, the LED will flash when the button is pressed. Follow Step 1 again if duplication
has failed.
TO LEARN GENIE ROLLING CODES:
Genie rolling codes require special additional instructions to program. Once step 1 through step 4 of the Fixed Code
Instructions are completed, you must do the following:
A. Pra•ce the SPR on the top surface near the rear of the original Genie
Remote instead of setting the two units side by side during Step 2 of the
Fixed Code Instruction; shown as Fig. 3
B: Press the Learn Code Button on the Genie Unit. The LED on it will keep
flashing.
C: Press the program button on the SPR. The LED on the Genie Unit will stop
flashing and become a solid glow
D: Press the same button on the SPR for the second time- turning off the
LED light on Genie Unit and finish the Genie Code Duplication.
E: Follow the EXAMINE CODE section of the fixed code instruction to test code duplication.
F. Follow the above steps if you wish to duplicate another Genie Code on your SPR.
NOTE:
If the first time you only programmed one button on your SPR, and you would like to program the second button later
on, either with FIXED CODE or GENIE ROLLING CODE, you will have to REPEAT step one of the fixed code
instruction to enter the leaning mode; then follow the instruction listed previously. After duplication, you will have to
repeat step 4 of the fixed code instruction for exit learning mode as well. This is very important.
Nov 07, 2011 | Brookstone 538744 Remote Control
Need a duplicate set of keys for my 1997 Aurora. Do I need to have this done by any keymaker (ex: hardware store), or must I have someone specialized in this type of key duplicate it? If so, how can I...
If you have the key with the "chip" or resistor in it, sometimes called the pass key, or smart key, you won't be able to have another key make that will work. You can have another key made that will fit the ignition switch, but if you use it,it will trigger the anti theft system and you won't be able to start your car, even with the crrect key.You can have a bypass system installed that will enable you to use any key, but it will disable the security system. Go to a website called "newrockies". They have an affordable bypass system that works.
Jan 13, 2011 | 1997 Oldsmobile Aurora
How do I delete duplicate songs on my Nano 4gb Ipod? How do I adjust the volume?
Using iTunes' "Show Duplicate Items" feature, you can locate and manually remove duplicate songs on your iTunes music library. Once the library is cleaned, you need only sync iTunes with your iPod to remove duplicates from your device as well. This guide takes iTunes 12 to remove song duplicates.
  1. In iTunes, click "View > Show Duplicate Items" in Music module;
  2. Compare the listed song duplicates upon artist, album, date added, genre, play count, size, bit rate, and more to determine which item to keep and which item to remove;
  3. Hold the "Ctrl" key and click each duplicate you wish to delete.
  4. Connect your iPhone 6 to PC, click your iPhone from the device list, hit "Music" and select "Sync" to sync your library using your existing sync settings.
By doing this, you could delete duplicate songs on iPod from your iTunes. But it will eat a lot time of you. To save your time, let's come to the 2nd method - using 3rd-party iTunes cleaner program.
http://www.leawo.org/tutorial/how-to-remove-song-duplicates-from-an-iphone-6.html
Oct 25, 2010 | Apple iPod nano
TOO MANY DUPLICATE MUSIC FILES
Below is a link to a FREE program, download and install it.
It will help find duplicate files (music, and others) to help free up space and organize your files.
http://download.cnet.com/Easy-Duplicate-Finder/3000-2248_4-10692636.html
Hope this helps, thank you for stopping by Fixya! Please leave a positive rating if this solution helps.
Mar 17, 2009 | Apple iTunes
Duplicate key
hi it will need codeing if you go to the dealers it will cost you arm and leg check your phone book find a auto electrician that also cuts keys and can code it for you as well you may have to get the key from dealers but ask the auto electrician he will know best place as far as reverse sensors the only simple change on these is the fuse as the rest are sealed modules unless someone accidently pulled the wiring off in the boot could have a quick check but if you get a auto electrician out for your key get him to have a quick look
Oct 13, 2008 | 2000 Jaguar S-Type
I don't know how to access my Western Digital Backup. I have no icon to click.
hi
If you have a WD Media Center, Dual-option Combo, or Dual-option USB external hard drive, you can use the Retrospect Express software that comes with the drive to create a backup schedule that will backup your data onto the drive.
To setup an automatic duplicate schedule in Retrospect Express 6.5 on a PC, please follow the instructions below.
  1. Start Retrospect Express by pressing the Automatic Backup button on the front of your Media Center external hard drive after you have installed the Retrospect software and powered on and connected the drive.
  2. You will be presented with the Western Digital Automatic Backup Wizard. Click Next to continue.
  3. Highlight the drive(s) that contains the data you wish to backup and click Next. To select multiple drives or folders, hold down the Ctrl key and make your selections.
  4. You will have a choice to backup your documents only or all files, make your selection and click Next.
  5. Highlight the drive you wish to copy your data to and click Next.
  6. You will have the option to run the data duplication daily or once a week. Make your selection and click Next.
    • If you choose a daily duplication, you will have to select the time that you'd like the duplication to start each day, then click Next.
    • If you choose a weekly duplication, you will have to select the day and time that you'd like the duplication to start, then click Next.
    • If you wish to run the duplication one time when you are finished setting up the schedule, check the Start the backup now box and click Finish. Otherwise, just click Finish.
    • You will see the Automatic backup button glow a solid blue. When the blue light is on it indicates that the automatic duplication schedule is enabled and your duplication is set to run at the scheduled time.
For the duplication to run successfully, you must have both the computer and drive powered on and connected correctly at the scheduled time.
May 28, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
