Question about Intel Motherboard
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
  • Doug Olmstead
    Doug Olmstead Aug 26, 2010
    it's a timing issue - press F1 at boot time. right after power up but before windows logo. some BIOS options can hide system setup request from being displayed.
    I have 22yrs exp maybe I can help for a small fee
    Problem Solver:
  • 8 Answers
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Posted on Aug 27, 2010
  • computerguy9 Aug 27, 2010
    I missed the first reply before posting my reply.
    I thought i would add that I have 15 years experience and I wouldn't charge a fee for what I just shared.
    Always glad to help someone in need when I am pretty sure I have a simple answer.
How to install bios
the bios is already on the board,
when you are booting the computer you have to push down on the F10, if that doesnt work than try F1 and thanF2, every time you try to enter the motherboard bios you have to start from a cold boot.
website for motherboard bios configuration and settings is at
http://www.msicomputer.com
if you want a copy of the bios setup and configurations and everything explained in detail go to your browser and type the following information.
MS-6758-040 BIOS MANUAL OR
MSI MS-6758-040 BIOS MANAUL
the bois controls everything the that runs you computer, video, ram, HD, CPU, PORT FUNCTIONS, BOOT SEQUENCE, SMART FAN CONFIGURATION, HD CONFIGURATION, TEMP. SETTINGS, AND ALOT MORE STUFF AND VERY LONG LIST.
MAKE SURE THE BATTERY IS MIN. 3VOLTS
Jun 25, 2014 | MSI MS-6758-040 Motherboard
I changed the battery on motherboard, it started and showed "checksum error press F1 to continue" pressed F1 everything ok, set up the time, date then restart the system, it is working but there...
You should press Delete to access the BIOS setting.
First you need to change the time setting.
Then you must change the Boot sequence from Removable Device to HDD where your first boot device will be your HDD which is where your Operating system is installed and the next thing your system will seek after the POST.
Hope this helps. Any vote is highly appreciated. Thanks =)
May 30, 2011 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
I think there is a problem with the bios. The computer start, but while starting the bios each input from mouse or keyboard result in stopping the system.
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive or boot into safe mode
hope this helps good luck
Sep 10, 2010 | MSI PT880 Neo FSR Motherboard
Every time I on my PC it appears in screen unknown bios error. error code 8302 press f1 to resume
You need to flash your bios before it becomes totally corrupted. You are losing small bits of information that your motherboard needs to continue functioning.
I have what i believe is the proper page for your bios, but your exact model doesn't show up when I search the site, so the best solution for your problem is the MSI live bios update located at the bottom of this webpage:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1150
Simply install that and allow it to automatically fix your bios for you.
Aug 05, 2010 | MSI P4M900M-L Motherboard
When i start the computer not bootup befor few days its working fine but when i start the computer its need always press f1 to continue i replace the cmos battery but still problem same but now a days its...
while computer starts before pressing f1 key press del key... you will go into the bios of *********** board... you can change these alert settings there... you will have an option that says wait for F1... select NO to that option and save the settings and exit from bios...
Aug 04, 2010 | AMD ASUS A7N8X-VM/400 Motherboard
UnKnow Bios error Error Code =8302 Sr, Computer Opening No Display ....F1 Press Continue Display Ok
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Aug 04, 2010 | MSI P4M900M-L Motherboard
Can not enter bios. first time starting this board up. when it starts it gos strait to the msi screen. it tells me to press delete to enter bios. when I do nothing hapens. looks like it does not want to...
The MSI screen will hide the memory count - you need to disable the loading screen to see the memory count.
Are you using a USB keyboard? USB is initialised in the BIOS, so it may not read USB devices the first time. Try using an older style PS/2 keyboard - that should work by default.
Mar 09, 2010 | MSI P35 NEO COMBO-F ATX M/board - Intel...
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
Feb 24, 2009 | MSI P4M900M-L Motherboard
Press F1 to resume
Try changing the CMOS battery (leave the battery out for 5mins then replace with new 1) if that does not work flash the BIOS
Let me know how you get on...
Matt
Dec 08, 2008 | MSI K9VGM-V Motherboard
Motherboard Bios
90% your cmos battery is lost charge,replace with new one and start the pc
your problem solved i hope
regards
prasanna
Mar 06, 2008 | MSI PM8M-V Motherboard
Intel Motherboard Logo
406 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
