Question about Microwave Ovens
I have a solis crema sl90 espresso machine and the green light won't come on. It stays red.
  • ralder4 Aug 27, 2010
    I have the same manual and there's is nothing about why the green light is not coming on. Thanks
    No one has answered my question. I have a solis sl90 espresso machine , only 9 months old and the red light stays on. Usually the red light stays on until its ready and than the green light comes on. But that is not happening.
  • Microwave Ovens Master
  • 12,061 Answers
Www.solis.ch/.../manuals/.../CREMA_SL90/CREMA_SL90_ENG.PDF
Above is you User manual, for your convenience.
Hi, when this happens with these units is means that the Unit cannot pass it's "Self Test" usually it is because it's element isn't functioning or the temperature thermostat has faulted, or indeed both.
Really there are NO DIY parts inside, and in my professional opinion you need to get it attended to by a professional, the best being the Manufacturer.
Usually the Manufacturer or an Agent, they will advise when you contact them, which is a MUST DO. If, you actually want it repaired and repaired relatively inexpensively, which is usually what happens when returned for repair. In any event you should ask for a "Quote" before allowing any work to commence. That way you can make an informed decision.
Posted on Aug 27, 2010
  • 3,083 Answers
I couldn't open this pdf file since my Adobe is acting up, but it looks like it talks about this problem:
www.solis.ch/pdfs/.../CREMA_SL90/CREMA_SL90_ENG.PDF -
I couldn't find any other info on this, so hope this helps.
Posted on Aug 26, 2010
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
My oven will turn on but won't stay lit (
The light may be loose, or one of the micro switches are going.
Apr 03, 2012 | Whirlpool Microwave Ovens
Overcooked green beens the alarm went off and then the power went off on the microwave for a minute then I reset the microwave and it started to work and then it lost its power and won't come back on
Most probably magnetron Unplug machine for one hr Open machine check the magnetron (hint check the resistance of the two terminals) using ohm meter If not Then call somebody I can help if you response me back with some more details Thanks Please rate my work
Sep 06, 2011 | Samsung Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
Hello, I have a Delonghi Espresso Machine (EC 155). I bought it 17 days ago and I have used it twice in a day carefully. Everything was perfect with my machine until 3 days ago. Then I observed these...
Your machine is new and its under warranty you have rights to replace it with new one. Call your dealer where you brought it, it's either they will replace it or send a service technician.
It will void the warranty if you try to unscrew something.
I hope my advice gives you an idea regarding your unit problem.
Mar 29, 2011 | Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
