Question about Sub-Zero Refrigerators
When I come home I find the refridgerator open and while it is still generating cold, the food nearest the door opening gets quite warm. When I find the door this way, the light is out. The fridge was built in 1990 and is built in with my cabinetry. I would hate to have to toss it!
  • 22,326 Answers
Clean the rubber seal around the door that may help,next if possible tilt it backwards as this will stop the door from opening as its tilting forewards and the magnetic door catch is weak with age ,or put a garden gate type hasp on it so cannot come open .tilting it backwards is the best bet if this is possible ,couple of pieces of lath under the front feet will do it
Posted on Aug 26, 2010
Amana Refridgerator freezes in the refridgerated cavity.
Many Amana refrigerators have something called an auto damper. It has a thermostat coil on the side of it and as the temps get colder the damper door closes. If the thermostat on the side becomes defective then the damper door will remain open or shut. If it remains open the food in the fresh food compartment will get so cold that sections will freeze. If you could send the model number of your Amana I may find a service manual with instructions that tell you how to test by removing and dipping the thermostat into warm or cold water to see if it is working properly. I will be here in and out to my other websites but would be happy to assist you and resolve this problem. Thanks Sea Breeze
Jan 21, 2010 | Refrigerators
My fridge is'nt working, but the freezer is but the fan comes on when the door is opened and it has become quite frosty. Its a hotpoint
You have to defrost your unit. This usually solves the problem. Remove your frozen food to a good ice chest. Put the refridgerated food in a seperate container ( another ice chest ) and unplug your unit, and open the doors over night. Plug it back in, replace your food an hour or so later.
Jun 23, 2009 | Refrigerators
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refridgerator not cooling
I always look underneith the ice box to see if cobwebs and dust buildup is clogging the fins and condenser motor. Clean that up all nice and she might work a little better. Look for frost on the back of the freezer, that indicates a bad heater. Listen for the fan motor in the freezer section. If it quits the cold air cannot get into the fresh food section. Check the damper (if applicable) to see if it is opening and allowing cold air from the freezer to get to the fresh food compartment. Look for to many food items in the freezer section blocking the cold air. If she needed freon you would fell absolutely no heat on the conderser coils below the ice box. MORE
Mar 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Dec 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator trouble shooting
Condensation only ever happens if the door is left open for a long period. - The warm ambient air condenses on anything cold - like the food in there.
Because of convection, the door need only be open 1/4" to be affected. Quite often a bag pushes the door open a little.
Check all door seals for splits - clean them.
Make sure nothing is touching the back cooling plate, and it should be fine from there.
Hope this helps.
Jun 11, 2008 | Refrigerators
MY refrigerator is running but is not getting cold.
This has several issues you might need to look into.
First, your refridgerator you selected shows it is a front load washer. I know that can't be right.
Second. Your temp setting. It should be set in a manner that allows the humidity to exhaust out.
Third, Your refridgerator compressor is about to go out.
Fourth, you are placing alot of warm food into refridgerator, and holding the door open too long. This sometimes shuts the compressor off.
Also peer behind your refridgerator. Is there alot of debris, dirt, brooms, etc behind there. If so clear it out completely.
On the front of some refridgerators there is a grill that can be removed carefully. You will see cooling fins on the inside of this.
Very very gently remove the dirt and debris off of this. The fins bend very easily, so becareful.
At the same time check drip pan, and empty if needed.
If none of these things seem to do the trick, contact a service technician, something tells me it is your defrost sensor, or compressor.
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frezzer icing up food frosting up.
The freezer must have been opened for a long time and than closed without defrosting or it has been filled with huge amount of food that was quite warm (especially if it is in warm room).
You need to turn it off, unplug it, move food to some cold place in the house and wide open the door to defrost and melt away all frost and ice. Make sure to be there to collect water.
When it all melts away, dry it up and turn it on on full power. Wait till it reaches desired temperature and than gradually fill it.
Apr 09, 2008 | Refrigerators
Ice build up in frezzer food getting ecesive frost.
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
37 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
