Question about Breadman TR2200C Ultimate Bread Maker
My breadmaker has stopped working. I unplugged it when the 'alert' light came on, so I re-plugged it in and waited for the 'alert' light to go off. Then I unplugged it and came to re-plug it in later on and it is not working. There are no indications on the display panel and it didn't beep when switched on, please advise
This problem happened to me twice in the past two years. The situation arises when any bread-making cycle is interrupted by switching the power off. I was was thinking that the machine was finished. The solution is to wait long enough (24 hours or more) for the internal cycle to reset itself. Since I couldn't study this problem at leisure, I cannot tell if the power should be ON or OFF. Just turn on the machine to see if it's over.
Richard F.
Posted on Sep 09, 2010
Got "Critical Alert Code 201" on Lennox air conditioning unit. Tech told me to shut off power to it then turn it back on, but that didn't seem to work. Any other suggestions?
Unplug the electrical. Wait 5 minutes and plug back in. See if that works. Have to wait a couple of minutes for system to reset.
Jul 02, 2016 | Heating & Cooling
Went thru a complete dough cycle, Turned the machine off. Cleaned the bucket, then went to start another batch. Nothing, no beeps, no lights. Is there a reset?
This happened to me also. What worked for me was to unplug the machine and wait at least an hour, then plug back in. It may reset for you. Good luck
May 08, 2015 | Cuisinart CBK-200 Bread Maker
My washing machine fisher paykel mw511 stopped working and now only beeps and show red light on spin. But don't spin or wash clothes
Is this the same company that makes Fisher-Price Toys?
I thought so, well you get what you pay for! OK most machines have some Reset function process. Most work by unplugging the machine for 5-10 minutes (computer to reset) then plug it back in. You should get a prompt/ audio or text message (if there is a window) that alerts you that the machine is resetting itself. Then just follow by testing a Light load setting so you do not have to wait around a long time. IF...This does NOT work. THEN...My Friend...You have a BAD control board. Which is like a computer board. And those are EXPENSIVE! $200-$400. So then it becomes economics. How old is the machine 5+ yrs? Buy another Machine
Mar 15, 2014 | Washing Machines
Cuisinart bread oven menu will not change
Plug your machine in and push the menu button again and again are the numbers changing from program to program? If not push the start/stop button with no ingredients in it and if it starts kneading wait a few seconds then push the start/stop button again UNTIL IT BEEPS AND STOPS. Unplug the machine and plug it in again and the program 1 should show again, just push the Menu button until you see the number 9 program. Did that work?
Dec 21, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
I have a K6774 breadmaker. Usually I press stop after 15 min. of kneading, so that I can start it over. This time, however, the three lights all came on. I unplugged the machine and then plugged it again...
Yes, it possibly was because it was a hot day. Please read on...
Regardless of what the original recipe or instruction manual says, the machine must be placed in a 70 to 80 degree low-humidity environment (60% or less), all ingredients must be brought to room temperature, adding water, milk, milk powders, oils, salts, cheeses, sugars and seasonings first, next the flour, and last the yeast, before pressing Start.
Exception to this rule: Fast-rise recipes used to create a finished loaf of white bread in under 1-1/2 hours. Water/milk for these types of recipes must be a warmer 110 degrees F and the standard active dry yeast must be replaced with fast-acting dry yeast.
Hope this helps!
Jun 21, 2011 | Regal Ware Kitchen Appliances - Others
It has stopped-no current at all. Plugs seem to be OK.
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 16, 2011 | Breadman Kitchen Appliances - Others
I have a convection bread maker. I made one loaf of bread tonight and i unplugged the machine. 30 minutes later, I tried to make a second loaf ant the menu select wouldn't work but the start and mix in...
Cuisinart has many different bread machine models. Next time you ask a question, please include a model number. Thank you.
Here's my generic best advice for you dear:
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    4. Some models require you press and hold the Select button down until the unit powers up.
    5. Some models require you press and hold the Start button down until the unit powers up.
    6. Some models require you select a mode first by pressing the Select button.
    7. Some models require you press and hold the Stop button down until the unit powers up.
Were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
Yes, Fantastic! Now reboot the breadmaker's electronics by pressing and holding down the Stop button down until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press and hold the Start button. Others require you press and hold the Select button.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You'll need to disassemble the breadmaker to visually confirm.
Jun 13, 2011 | Cuisinart Kitchen Appliances - Others
Breadman Pro TR875 is stuck & will not start up to knead the dough. Timer is hi-lighted & shouldn't be. No pushing of any buttons will not clear & start over
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    4. Some models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Some models require you press the Select button first before pressing the Start button.
In the end, were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
Jun 07, 2011 | Breadman TR900S Bread Maker
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
My machine was unplugged for no more than 3 seconds during kneading. it is quiet now and on ALERT. on a 5 hour whole wheat xl loaf..now at 3:02. how do i restart it and move it off of alert
If you feel your dough has kneaded and risen enough, try pushing the stop button until it beeps. Then unplug and replug and select the bake stage and using the timer feature put enough time on the bake cycle to equal the bake time of your original whole wheat bake stage. That time should be on your page in the manual that shows the length of all the programs.
Oct 28, 2010 | Panasonic SD-YD250 Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
191 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
