Question about Vacuums
We own a Hoover V ac Ve Deep cleaner Model # 73502 02482 or F7425 - 950 Serial # 110200001908 and we are in need of a Clean Water Tank. Can you help us find one. Thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=575543
Generic problem for all Vacuums
We own a Hoover V
Posted by dgodard on May 06, 2008
We own a Hoover Vac V Deep cleaner
Can you help us find one? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The best way to locate a clean water tank is to 1st try your local vac dealer in your area for a new or a good used one that would work for you, or to contact the Hoover Factory and they can ship you out a new one or they can refer you to someone who can ship you one. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 06, 2008
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water leaks
This model has a resevoir with a diaphram valve. The location of this part in under the clean water tank it has a black round gasket.. Your problem could be a bad resevior or something mechanical with the trigger and rod that when you pull on the trigger, solution is released.
Jan 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
66 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
