Question about Intel Motherboard
Msi ms-7048 medion md8083 can i use a pci usb 2 expansion card in this pc. can you recommend a card thanks. df
  • derek_fraser Aug 27, 2010
    thank you very much for solving my problem i will know where to come next time for help. df
  • 4,472 Answers
  • Lee A.
    Lee A. Aug 27, 2010
    Your very welcome. Have a great day,
    Lee
How to add usb ports to Dell 530
Suggest use a USB adapter card.
More specifically a PCI USB adapter card.
Dell Support > Inspiron 530 Series Desktop PC > Owner's Manual,
http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/index.htm
In the list click on - Removing and Installing parts
1) Unplug the computer from power.
[Unplug FROM the surge protector, not the back of the computer. (Power Supply)
Unplugging from the back could lead to a power surge ]
2) Computer on a table open the computer case,
Click on - Removing the Computer Cover - in the list.
3) FOLLOW Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware inside the computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
4) http://support.dell.com/support/edocs/systems/inspd530/en/OM/HTML/parts.htm#wp1184332
Here you see an illustration of your motherboard. Oriented as it is in your computer case. (Just no hardware components, nor cables are attached)
At the bottom of the motherboard are 2 White long expansion slots.
In the illustration they are labeled by the numbers 21 and 22.
If one of these slots is open, and not being used, you can install a PCI USB adapter card.
This is one example of a PCI USB adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606148&Sku=S262-2744
At the back of the computer, located towards the bottom, are the Expansion Slots.
Four horizontal slots.
If there isn't some sort of add-on adapter card already installed, all of the expansion slots will be covered with an Expansion Slot Cover.
If there is an add-on adapter card installed of course, one of the expansion slot covers will be removed.
Line up the PCI USB adapter card with the open PCI slot, you have chosen.
Now look at the expansion slots at the rear of the computer.
Notice what expansion slot that the PCI USB card's bracket, lines up with.
Go to the back of the computer, and view the small metal bracket on the bottom right. Loosen the Thumbscrew, and swing the bracket out. (Thumbscrew is supposed to just loosen, not come out)
Remove the expansion slot cover for your PCI slot choice.
Install the PCI USB adapter card.
Note that there is a Locating Lug in the PCI slot, and a matching Locating Notch, on the PCI USB adapter card.
Line them up, then push the PCI USB card straight down into the PCI slot.
Also watch the metal bracket on the back of the PCI USB card.
The 'tang' at the Bottom, slides down in-between the framework.
The top of the bracket has a half-moon notch, that lines up with a small 'dowel' on the computer case framework.
Make sure it is aligned, and the bracket is aligned.
What I am referring to will become readily apparent, as you go to install the PCI USB card.
If there are any other add-on adapter cards, they may try to fall out, when you go to install the new add-on card.
You just have to line them up, so their bracket notches are all on the 'dowels', and hold them in place. Then swing the 'door' closed. Tighten the thumbscrew.
If you have an Add-on card in the way, and by moving it to the other PCI slot, will allow you to install the PCI USB card, go ahead, and move it.
Doesn't matter. BIOS will find it, and assign an Interrupt Request.
There are two other expansion slots above the 2 white PCI slots.
The expansion slot right above the top PCI slot, is a PCI-Express x1 slot.
If this slot is open, OR the only one available, you can use a PCI-Express USB adapter card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5606149&CatId=511
The last expansion slot you have is above the PCI-Express x1 slot.
This is a PCI-Express x16 slot, and is ONLY used for a graphics card.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 13, 2012 | Dell Inspiron 530 Desktop Computer...
What graphics card compatible for ms 7057 mother board
Looks like that motherboard only has PCI slots to use. You can choose any video card that connects to a PCI slot(Not PCI-e, PCI express, or AGP).
Feb 17, 2012 | MSI 845GVM-V (MS-7057-010) Motherboard
Hello! my problem is that my two USB ports is blown. Now I want to connect more USB port on the motherboard via cable, but none matches the port that the USB or sb_link, jp1... Can you tell me which port...
You will need to get a usb expansion card. These can be found at Best Buy, Newegg.com, tigerdirect.com, pc-connection.com etc...
Some manufactures ship with newer motherboards a usb expansion slot using the motherboard jumper configuration but your motherboard must first be able to support this type of expansion.
I recommend the pci usb expansion. They plug into your PCI slot and give you 2-4 extra USB slots in the back of your computer.
Mar 01, 2011 | Quadrant Slot 1 QM-6VABX2 (QM-6VABX2-1664)...
I,ve lost my driver cd for my medion pc model ms 7048 and don't have credit card or enough money to order for another please what do i do. help me!
Here's what you need to do:
MD8088 MSI MS-7048
  • Click "MD8088" to start downloading the installation files
  • Open the setup application and follow the onscreen prompts until completion
  • Restart your computer
Enjoy, and Thanks for using FixYa
Feb 19, 2011 | Microsoft Computers & Internet
Hi i have ms 6714 mother board how to know its 040 or 020
1) The Micro Star International MS-6714-020 motherboard uses an Intel 845GV motherboard chipset.
Underneath the Heatsink on the Northbridge chip is the part number Intel 82845GV.
On the Southbridge chip the part number is Intel 82801DB. (ICH4)
2) The MSI MS-6714-040 motherboard use an Intel 845GE motherboard chipset.
Underneath the aluminum ribbed Heatsink on the Northbridge chipset is the part number Intel 82845GE.
List of Intel Chipsets, and specifically the one's for the Pentium 4's,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
How to know the difference without knowing what part number is on the Northbridge chip?
Easy.
The Intel 845GE supports Integrated Graphics, and AGP (AGP 4X)
There is an AGP expansion slot on the motherboard for using an AGP graphics card.
The Intel 845GV supports Integrated Graphics only.
There is No AGP expansion slot.
Just the three white PCI expansion slots.
Regards,
joecoolvette
Dec 14, 2010 | MSI 845GVM-L (MS-6714-040) Motherboard
We have an emachine w3400 and need and new video card but don't know if it is PCI standard or PCI express how do i find out?
The eMachines W3400 desktop computer has an MSI MS-7145 motherboard.
(MSI = Micro Star International, Inc)
This is the MSI MS-7145 motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket754/msi7145.shtml
The MSI MS-7145 motherboard, has one PCI Express x16 expansion slot, which is used for a graphics card.
Viewing the bottom left of the photo, you will see three white PCI slots.
Right above them is a longer white slot.
This is a PCI Express x16, expansion slot.
Scrolling down to the subheading - Expansion Slots,
You will see - One PCI Express 16x slot, listed.
Should you require information in installing a PCI Express graphics card, or information on which PCI Express graphics card may fit your needs, state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
Motherboard model number
you can see on the motherboard.watch carefully...
Mar 09, 2010 | Computers & Internet
Mijn tv kaart Philips 713x Inbox PCI TV Card werkt niet is een combo kaart Creatix SAA7134, Hybrid Capture Device Medion PC MS-7048
Для сколько можно гонять по ссылкам ,утерял дрова на этот гребаный тв-тюнер0,игде его можно скачать
Jan 12, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I do not have ethernet driver my mother board is msi ms 6367n2 plz help and i o so need bus sm tks
This is an extremely old PC, the driver is not even available from MSI's driver archive.
I recommend buying a PCI ethernet card, that'll have the driver on a CD with it.
Jul 07, 2009 | Computers & Internet
USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Apr 28, 2008 | IBM NetVista A40 PC Desktop
Intel Motherboard Logo
572 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
