Question about Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger
911 series Ariens lawn mower's primer does not prime. When pushing primer it just goes flat and can tell by the fill that it is not priming. Therefore the lawn mower will not start.
5 Suggested Answers
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
SOURCE: lawn mower will start when primed but will only run for few secon
It starts because of excess fuel from priming. It usually then gets it fuel from main jet in carb.
You need to find the main jet and run a fine piece of sturdy wire through it. That will restore fuel flow so your mower can continue running after the priming fuel is gone.
This is a good thing to learn. Main jets tend to clog a lot on mowers these days.
Posted on Jul 06, 2010
hunter19_46m
  • 7482 Answers
SOURCE: my ariens mower will only start wen primed and then thats all i get
Hi paul
Posted on May 01, 2013
The primer bulb doesn't fill with gas
sounds like you hasve a cracked fuel line or a cracked primer bulb. that is why it cant prime.
Aug 29, 2015 | Swisher 190cc 22" String Trimmer Mower...
How to replace carburetor priming bulb on braggs stratton engine?
you will need a sharp flat blade screw driver first take screw driver and pry out metal retaining clip once out pull out old primer ball the push new in till its seat all the way around get new retaining clip push it over primer take a socket same size as retaining clip push the ring down until seated your are done
Aug 28, 2014 | Garden
My Ariens lawn mower dose not get gas to the Carb float is OK gas line OK.When I push the primer button No gas. Spayed Carb cleaner in carb No change. What can I do next?
You have gas in the float bowl but nothing coming out when you prime correct?
You should remove the bowl jet *(should actually be the bolt that holds on the bowl) and wire brush it clean and then run a fine piece of wire strand through the jets. One of those openings is very tiny.
It is located at the top of the threads and you will need a tiny piece of wire strand to clear this. When you have cleared this and the two bigger openings at the bottom of the bolt put it back in and see if she primes. The primer just puts a raises the air pressure inside the bowl so fuel flows up the main jet. So a blocked main jet will prevent priming and running at anything above idle speed.
Good luck and be careful!
Jul 23, 2010 | Garden
Model 911514 starting problems
If this model has the Tecumseh engine, you should have a primer button on it. These can go bad and the fuel lines also. Check to see when you prime it if fuel is flowing through the lines. If not replace the button and the fuel lines. Be sure to make a sketch of where the lines are hooked up.
Apr 28, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Fill with gas and prime won't start repeat 2 or 3 times and it will start
Try giving the primer quick jabs not slow pushes. Also make sure to cover the small pin hole on the primer if it has one. It may just need a new primer. it could not be sealing right or have a small wrip. Hope everything works out for ya.
Apr 05, 2010 | Garden
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Sep 27, 2008 | Garden
Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger Logo
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
