Question about Xerox C2424 Copier
Paper format manual tray
How can I ask the printer to convert automatically paper format from letter to A4
    President:
  • 2,072 Answers
With as close as they are I don't see anything, I have looked through tips and manuals.
Try calling 1-800-821-2797 and ask for second level support.
if it can be done they can tell you.
Posted on May 06, 2008
Put A4 in upper tray error
Change the printer properties to use paper from the automatic feeder tray. And, unless you are in Europe, you probably don't want to specify A4 paper. Try "letter" or some other size.
The manual is at this URL. See page 49 http://www.manualslib.com/manual/113847/Oki-B4545-Mfp.html
Apr 25, 2016 | OKI Office Equipment & Supplies
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
Machine is asking to: Load manual Feeder with Custom Type 1 Letter
in the printer properties during printing change the "paper size" from letter to a4
Jan 23, 2014 | Lexmark Xs736de All In One Laser...
I have a lbp 7200 and even when the paper tray is full as soon as I go to print it tells me to load paper ?
I had this problem and solved it because the paper format of the tray was set to Letter in stead of A4. A4 is what we use here in Europe, so I guess the Letter format was conflicting with an 4 setting elsewhere. Settings - Paper size - A4 solved the issue.
Mar 19, 2012 | Office Equipment & Supplies
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Print jobs stick in prnt queue
    A lot of users have no idea how to change the MS Office default from US to UK .. so they have US spellings and US paper sizes (known as 'Letter' sized) .. and (of course) any Document that started life in USA keeps it's size until some-one changes it ... since Letter size is almost the same as A4 no-one cares UNTIL they come to print it ...
    I'm sure you can guess the rest :-)
    Yes, the Printer is looking in it's feed tray for Letter sized paper .. yes, Letter doc's will print just fine on A4 and most printers have a setting somewhere that lets it use A4 when asked for Letter (often called "automatic A4<>Letter convert" or some such)
    NB. when time permits, perhaps the unfortunate users can have their MS Office apps. set to UK mode :-)
    Mar 17, 2009 | Dell Office Equipment & Supplies
    HP Laserjet 3050, need to press ok each time printing
    did it work before? check paper size for trays - suspect it is set for a4, change to letter size
    Mar 12, 2009 | HP LaserJet 3050 All-In-One Printer
    Only wants to print out of tray 1
    paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
    Nov 30, 2007 | HP LaserJet 4350 Printer
    Xerox C2424 Copier Logo
    74 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
