Question about Refrigerators
Hey guys, fridge went warm, frezer fan is on- think it is the relay. would top of compressor still be hot?
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Samsung rb2055sl running warm 55 degrees in refrigerator and 70 degrees in freezer fan is working no ice, way to warm
Is there a clicking noise? Feel the compressor to see if too hot to keep your hand on top. Look ate the frost pattern in rear of the freezer compartment and tell me the results. Several things could be causing the compressor to get hot and not run. Freon leak is one thing that could happen and defective start relay, overload and run capacitor is another. You could also have a defective cooling fan under fridge or inside the freezer compartment
APPLIANCE 911
Sep 18, 2016 | Samsung Refrigerators
WAS WORKINIG FINE NIGHT BEFORE WOKE TO IT NOT WORKING FRIDGE AND FREZER BOTH I DID HERE THE FREZER FAN RUNNING STILL. THE COMPRESSOR TRIES TO GO ON BUT SHUTS OFF RIGHT AWAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frezer ok, fridge warm
clean coils on back or underneath the fridge and make sure the 2 controls are set right, also check that fan in freezer is blowing. If there is a fan by the compressor see that it is working
Aug 05, 2009 | Refrigerators
Inside of fridge is hot. everthing is spoiled
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 12, 2009 | Magic Chef Refrigerators
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
May 13, 2009 | Maytag Appliances Magic Chef 18 cu. ft....
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
To cool the compressor?? I do not have a problem, this is just a general discussion question I'm throwing out there. Every fridge I've ever owned, the compressor gets very warm/hot after running. I have a...
Some compressors are designed to be externally cooled some are not.
They have to process the refrigerant to certain pressures to operate correctly.
The specific condenser and expansion device do the rest.
By cooling a compressor artificially you make it work harder to do its' job.
Cooler is not always better.
Feb 22, 2009 | Frigidaire FRT15G4B Top Freezer...
Kenmore 106.52274202 not cooling
By you description of the problem and this model of fridge it sounds like the the relay on the compressor has failed and will need to be replaced. Especially if this happened overnight.
Nov 25, 2007 | Refrigerators
Constantly running
If the thermistor sensor for the temperature control is going out that could cause the compressor the think it needs to keep running to cool the unit. The fan near the compressor should run only when the compressor runs. If the fan is running and the compressor isn't then you likely have a compressor start device problem or the overload is tripping from high heat, etc. That would make the compressor run (or try to) every minute or two if not just run continuously. Make sure all the coils under the unit are clean of fuzzy's and hair, etc. by doing a good vac. clean on them also. The compressor can be slightly warm to the touch but shouldn't be so hot that it is hard to keep you r hands on it for long. If it's around 130 degrees F, then it may be the start device problem and is in an overheat condition.
Dec 09, 2006 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
