Question about Lexmark C510 Laser Printer
Lexmark C510 Code error: 995 Service Engine Error
Hello, I have a Lexmark C510 Printer that starts to go through it's power-on procedures then pop a "995 Service
Engine Error"
Please suggest me about that error.
  • 1 more comment
  • Anonymous May 21, 2008
    995 Service Engine Error problem,
  • Anonymous May 25, 2008
    My Lexmark C510 will not print. Displays 995 Service, Engine Error. What is the problem?
  • nsfirepro Dec 23, 2008
    I have a 995 service engine error problem. I have to turn power of and then on again to clear. Problem seems to be comming more frequent.
Posted on Feb 18, 2009
  • 65 Answers
Check your toner cartridges and photoconductor. Some of them having trobules pulling the gears around. Try to turn the gears at each unit manuelly, and replace the one with the stuck gears. Good Luck.
Posted on Jan 05, 2010
I had the same problem, I changed the photo conductor and it was ok.
I disassemble that part, all the bottom, I clean it with air, they were a lot of ink in, and after that, it works correctly.
Be careful not to touch the photo conductor with your finger, and avoid having strong light on it
Posted on Oct 03, 2008
How can i fix the photodeveloper error?
Does the error it shows have a code number, such as "995" or similar?
Jul 11, 2014 | Lexmark C510 Laser Printer
Lexmark C510 can not print and display with 994 service engine error. How to solve this problem. Thank you very much
Please click on the link to see instruction on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Jun 08, 2011 | Lexmark C510 Laser Printer
Lexmark C510 995 Service Engine Error: I can turn All four toner cartridge gears, but they all seem to turn quite hard by hand. Is that my problem?
shut off power to printer. Pull your photoconducter unit out and check the position of the black marker located on the edge of the tranferbelt. I know one time I was fortunate enough to fix this error by rotating the photoconducter belt so that the marker was in a different position. Becareful not to touch the photoconducter belt (green shiny part) if at all posible. Reinstall the unit and power up.
2. If the above trick doesn't fix it after turning the printer off for a few minutes and you still get the same error when printing... You will have to replace the photoconducter unit. I wasn't as fortunate the second time I attempted the above trick and ended up having to order a new one. But hey its worth a try!!
Jan 30, 2010 | Lexmark C510 Laser Printer
The error 995 refers to a problem with the High Voltage Power Supply. This could mean three things one is that the Photodeveloper cartridge is damaged and needs to be replaced. The second one could be a problem with the High Volt Power Supply not providing enough charge to the Photodev. The third thing could be that the Engine Board is damaged causing the error in the display. You can try to reset the Photodev by pulling it out and the seating it back in the printer.
Jan 08, 2010 | Lexmark C510 Laser Printer
C510 printer displays "994 Service Engine Error". How do you address this?
From a previous post: Posted by waynechurch on Apr 24, 2009 Is this error on a C510?, because the manual lists 994 as OPC belt marker sensor error.
Normally with an engine service error i reflash the engine firmware first, if that doesn't cure the fault i would then replace the engine board. If you need the firmware, visit the Lexmark site get the contact phone number for your region and ring them. They're normally quite helpful and of coarse can tell you how to reflash it.
Sep 25, 2009 | Lexmark C510 Laser Printer
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
I have a error message on my Lexmark C510 printer that reads: Invalid Engine Code. The printer will not print. Any suggestions
Recycle the power a few times, if that doesn't work first reflash the engine firmware (you would need to contact Lexmark for that) failing that replace the engine board.
Apr 23, 2009 | Lexmark C510 Laser Printer
Lexmark C510 - Printer will not print
Invalid Engine Code
What this message means:
The printer engine code has not been programmed or is not valid.
What you can do: [Not much]
Call for service.
See also: Calling for service
Dec 04, 2008 | Lexmark C510 Laser Printer
913 Service Fan Error
your printers power section does not work properly
Jan 25, 2008 | Lexmark C510 Laser Printer
Lexmark C510 Laser Printer Logo
2,530 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
