SOURCE: Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
SOURCE: 1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
GOOD LUCK, EVERYONE!!!
SOURCE: dell 1720 dn broken output flag
You can find a junk 1720(dn doesn't matter) and replace the top cover assy. yourself, or you can replace the printer(usually cheaper). Sorry, this is usually terminal for these printers.
SOURCE: How to reset to factory default Dell 1720 network printer
1. Turn off the printer
2. Open the front cover.
3. While the Continue and Cancel buttons are depressed, turn the printer on.
4. When the error LED on the control panel is lit solid, close the cover.
SOURCE: how do I change the
Ok the following instructions will help you reset the ip address of your printer however you must use the origina driver cd to do this. Follow the instructions below if you have no print server involved with this network. If you do use a print server let me know ok?
Print and Check the Network Setup Page
If Status is Not Connected:
ping xxx.xxx.xxx.xxx
If the printer is active on the network, you will receive a reply.
If the CD does not automatically launch, click Start® Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
Install Printer Drivers for All Clients
If the CD does not automatically launch, click Start®Run, type D:setup.exe (where D is the drive letter of your CD), and then click OK.
1. On the control panel, press the Menu button, then press the OK button to select
Information.
2. Select Info Pages, then press the OK button.
3. Select the appropriate information page, then press the OK button to print.
Note
Print the "Menu Map" to see other information pages available for printing.
Hope this helps
Kevin
