Question about Kitchen Ranges
I need a manual and electric diagram for airco ac/dc heliwelder 4 300 amper code#0665 stock#1341-0176 s#mh101068
I need a manual for a airco welder. Stock number1341-0266. Serial number hk220507. Thank you.
This was made by Miller. It is the same as a Miller Dialarc 250 ac/dc.. Go to www.millerwelds.com, then "service", then "owners manuals" then "search", and scroll down until you find the dialarc.
Apr 22, 2015 | Welding Tools
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
Output:
This is what you need to know.
What is the output voltage of the original charger?
Example;
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Regards,
joecoolvette
Jan 25, 2013 | Computers & Internet
Service manual
HP AC adapter, HP part number 416421-021?
http://www.amazon.com/Compatible-HP-416421-021-Adapter-Charger/dp/B0050DN8X8
Plug going from AC adapter to DC Power Jack on laptop;
Center of the plug is the Positive ( + ) connection.
This is where the red Positive probe lead of the multimeter goes.
The outside cylindrical metal shell is the Negative ( - ) connection.
This is where the black Negative probe lead of the multimeter goes.
The Function knob should be set to DC Voltage.
(Unless you have a multimeter, that automatically detects whether it is AC, or DC voltage you are testing)
If more than one scale set it to the 0 - 50 Volt scale.
You should read VERY close to 19 Volts.
[Label on AC adapter.
Output: 19V / 4.74A
19 Volts at 4.74 Amp's. (Amperes)
Don't worry about the Amperage, just the Voltage ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 10, 2012 | Computers & Internet
Treadmill NTR 800 Error 0665
see you instruction manual and go to section troubleshooting for proceed.
If you do not have i.manual go for free download ;www.fitness.manualsonline.com or www. iconservice. com
Whatever the error code mean, please lube your deck belt, test the drive belt, and see the motor if there are running.
sincerely. God bless you.
Apr 26, 2012 | Exercise & Fitness
NEED A WIRING DIAGRAM FOR A DC-600
Here's your Lincoln Idealarc Owner's Manual.
If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 25, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
M and s telephones T04/8811/6052, can anybody advise the output voltage from the mains adaptor?? many thanks
Hi,the best info is ;
Electrical power Handset - 450mA Li-ion rechargeable battery Pack
Base unit - 7.5V DC 300mA
Charger pod - 9V AC 300mA
Just to make sure and verify this info , pls look closely to the power plug input of the telephone unit it should be a molded some figures i.e. 9VDC and ( -)(+) reminder for the tip of plug of adapter
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
M&S technology customer services:
tel 0845 671 0665. Mar. T04/ 8811 /
www.binatonetelecom.com
Jul 28, 2011 | Kitchen Appliances - Others
Lost ac/dc adapter
Hi, for a 12v 2 ampers device any universal laptop power suply can be used. They usually are tesignedfor about 2-4 ampers so it won't be a problem. All you have to ake soure is the correct polarity, and the changeable dc plug.
good luck.
Mar 20, 2009 | Kogi L7CH Monitor
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
