Question about Mach Speed Trio DA-8033 MP3 Player
Trio mp3 portable player
I bought a new mp3 player, I formatted the player, but after formatting it I lost the icons and now I get an internal error. Why did this happen and how can I fix it?
    Problem Solver:
  • 13 Answers
I would remove the batteries for an hour, then format it using Windows Explorer--do a complete format--then remove it using the "safely eject hardware" icon (always!). Insert a battery, then plug it in and, hopefully, you'll be able to drop .mp3's right in and have them play.
Posted on May 16, 2008
  • BigOldCar May 16, 2008
    Somebody else posted this, which might work for you as well:
    Here's how I fixed mine:
    Turn on your MP3 player, it should be blinking. Plug it into your computer and wait for it to link up. Then use your computer to format it, THIS WILL ERASE EVERYTHING, so copy off your music before hand.
    Then go to this web site and download and install the software:
    http://www.machspeed.com/tech/firmupdate...
    Now when you start the software, if it doesn't find your MP3 player (it didn't find mine) it will say your firmware version is 0. Go to the DETAILS button. It will list four files (it will show five but two are the same file) for he update. Locate these files on your computer and copy them to you MP3 player.
    Pull out your MP3 player, and it should now work. Hope this helps.
    Talerith
My way of fixing the problem was that I went out and bought another one.
Posted on May 07, 2008
Keep getting format errors when trying to play a movie
Hi numisis2008
Sorry, but your player does not play movies...it only uses MP1, MP2, MP3, or WMA formats which is only for audio.
Go to the following webpage and download you Trio user guide.
Inside it will tell you all about your player and what formats to use.
Please take time to rate me
Bud
http://www.machspeed.com/manuals/8033manual.pdf
Oct 25, 2012 | Digital Audio TRIO MP3 Player
When i turn my mp3 on , it says " File System Error " , But when i connect it to my computer it'll show that it's charging . How can i fix this ??!!!!!!
This error occurs sometimes with the player. Please format your player via your computer so as to solve it.
IMPORTANT:
Formatting will erase all data on this player. Make sure you have backup all data on this player before execute the formatting.
  1. Connect your player to your computer.
  2. Double click My Computer at the desktop on your computer. You will find an icon for your player.
  3. Right click your mouse to select Format... in the popup menu.
    • If you can not find the Format... option after you right click the icon, please double click the icon, you will find another icon named Internal Storage, right click this icon to select Format.... You may get a warning message, click the OK button to start the formatting.
  4. Click the Start button. The formatting will auto start. You will get a message Format complete when the formatting is finished.
  5. Transfer again your backup data as you did to the player.
Please revert for any further issue.
Regards
Anand
Apr 27, 2011 | Philips GoGear HDD6330 MP3 Player
My device NWZ-B133F once is powered on, it displays boot error
This issue may occur if the portable player was formatted via Windows Explorer. Follow these steps to correct this issue:
NOTE: If the message you receive is Format OK? , select Cancel .
1. Connect the player to the computer.
2. Click Start and then click My Computer .
NOTE: If the Portable Device box appears, click Cancel .
3. In the My Computer window, under Other , double click the icon for your portable player.
4. In the My Computer [Name of your device] window, right click the Internal Storage icon and then click Format from the menu.
5. In the Format box, click OK .
6. In the Format Complete box, click OK .
7. Close the My Computer windows.
8. Disconnect the portable player from the computer.
9. If it is not on, press the power button to turn it on.
10. Press the selector button repeatedly until Settings is highlighted.
11. Press the Play / Pause button.
12. Press the selector button repeatedly until Format is highlighted.
13. Press the Play / Pause button.
14. Press the selector button one time to highlight OK .
15. Press the Play / Pause button.
16. Once the player has finished setting up, Music Library will appear in the display and you can now use your portable player.
17. Test the player for proper functionality. If the error still occurs, reset the player by pressing the RESET button with a small pin or similar object.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Thanks for using FixYa.
Apr 07, 2011 | Sony NWZB133F MP3 Player
My sony mp3(nwz-b133f) got boot error how to slve it
Apr 06, 2011 | Sony NWZB133F MP3 Player
Trio v430 is not recognizing my expansion memory card unless I remove and reinsert it each time I turn it on.
In this case I'd suggest that you format your player. Contents may be removed by using this function. So make sure to back up your contents. You can sync your player with Windows media payer version 10 or above.
Here is how to format it:
1. Connect the MP3 player to a working USB port. Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending on your system configuration.
2. Right click on the removable drive icon which is your player's icon and select format from the drop down menu.
Your MP3 player will now start formating. Follow onscreen instructions and disconnect when format is completed.
Hope this helps.
Mar 18, 2011 | Mach Speed Trio V430 MP3 Player
Dear sir, when i turn on my nwd b105f walkman, it is swhowing that' boot error, shutting down'. it was functioning smoothly before and i tried to delete the songs and formatted. this error happened after...
Mar 10, 2011 | Sony Walkman NWZ-B105F MP3 Player
Trio TCH843 MP3 Player: Have a new Mach Speed Trio TCH843 and wonder, whet...
I FOUND THE SOLUTION!
Hi. If you're like me you just bought one of Mach Speed's mp3/media players (I have the Trio/Eclipse Model G2, it looks like the Ipod Nano). I bought it at Big Lots for about $30. Everything works except i can't get video to play on it! Here's what i found after hours of trial and error:
Seems mine (hopefully this will work for yours) will ONLY play either FLV or RM files. If you have AVI or other kinds of video files you can use this great software to convert to FLV:
http://download.cnet.com/Koyote-Free-FLV-Converter/3000-2194_4-10832044.html?tag=mncol
It's free and it won't put a watermark on the video...which is great 'cause all the other free ones out there will. Anyway i hope this helps.
May 18, 2010 | Mach Speed Trio TCH843 MP3 Player
Most videos I add to my mach speed trio v430, are in avi format, but when added to the player say file format error! they play on my computer in the VLC player, so i do not understand why they do not play...
Dec 02, 2009 | Mach Speed Trio V430 MP3 Player
Mach Speed Trio DA-8033 MP3 Player Logo
73 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
