Question about Yamaha Boating
2003 yamaha AR210 jet boat, tach not working
2 Suggested Answers
  • 512 Answers
SOURCE: I have a Yamaha Tach/Hour Meter 1/10. I cannot turn it off. Boat batteries are disconnected and I have disconnected the tach/hour meter. It keeps flashing
From what I have gathered on the internet, it doesn't turn off. When running it displays RPM, when engine off, displays run time. Estimate for the internal battery was 10 years, but I wouldn't bet on it. This is a sealed unit and priced low enough that after a few years it is a throw away. Liquid Crystal displays use very little power, micro micro amps, and it is possible that it is designed to charge itself when the engine is running off the pulses from the plug wire, micro amps at a time. All that said, I don't think you have a problem, just need to read the instructions and see if they say anything different, I couldn't find them online so hope you have them.
Posted on Sep 27, 2012
Yamaha outboard 90/65 4stroke jet only getting 5000 rpms. New motor with 6 hours on19' flat bottom boat. Tach is flashing a engine symbol. Suggestions?
The amount of RPM's on a boat motor depend on a number of things...
1. Height if the motor in relation to the bottom of the boat. - too high and it over rev's.. Too low and it won't rev..
2. The correct size (O.D.) of the prop. Too large and you have mechanical interference or too large for the motor to spin...- ..Too small and the motor will over rev!!
3. The correct pitch of the prop. - Too large/big of pitch and the motor can't spin it..-.. too small and it will over rev the motor.
..... these are the big three...
Now, Make sure the carburetor butterfly(s) are opening exactly flat or vertical ...and not under/over opening..if this is a fuel injected motor...have the dealer check it out..
Jul 11, 2017 | Boating
Yamaha Exciter jetboat: eng stops when warm, not overheating
I have a 1998 Yamaha Exciter jet boat as well and am having a similiar problem. I just took it in today and the mechanic believes that it may be the oil pump failing which causes the pistons to stick and not lube the engine properly, thus causing overheating and eventuallly stall. The one motor sounds beautiful and the other sounds unhealthy. He checked compression and it seemed fine and it has new plugs. Maybe this is the same problem you are having...Hope this helps...
Mar 24, 2010 | Yamaha 12V Air Pump
I have a 2003 yamaha yzf 600 the tach dosent read correct
I do not believe so, as the tach is related to your firing electrical pulse. have you checked the tach wiring for loose connections?
Mar 22, 2010 | 2003 Yamaha YZF-R6
Hello, I wanted to see if you knew what the symbols on the yamaha outboard digital tach are. The one I have does not have any buttons or total hour meter. The symbol I was wondering about is to the left of...
The gauge is for a Yamaha with a remote oil tank. Low oil and no oil. the manual is available at yamaha motors.com. in pdf download format .the year will be almost impossible to find out. the part number can be found at your local dealer. a good parts person can find that by just your description
Oct 24, 2009 | Boating
2003 yamaha 50hp 4 stroke, won't start
sounds like you are going to have to pull carbs off and clean jets also check tank and line for debries
Sep 03, 2009 | RTO Oar Sockets
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
Apr 12, 2009 | Sport & Outdoor - Others
Boating Logo
119 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
