How do I raise the top to access the lid switch to replace it
  • Colleen Rodriguez
    Colleen Rodriguez Nov 30, 2008
    I also have a Roper washing machine, model number RAS8445KQO, and it will stop when the tub has filled and started washing but between the wash and rinse cycle it just stops.  It used to be that if I went and put all of my upper body weight on the lid, it would start back up but today even that stopped working.  I see from many google searches that the solution seems to be replaceing the lid switch.  How do I access that and replace it as I have never attempted anything even close to that.
  • 1,073 Answers
What is the model number
Posted on May 06, 2008
How can I fix the lid of the washer comes down to close and it pushes down on a mechanism that allows the washer to drain and spin, that mechanism how can I fix it ? broke
If it is a top loader you will need to raise the top lid. There should be two spring catches in the front joint about 3 inches in from each side. The springs need to be pushed in to release the catch. with a screwdriver or perhaps table knife or with another thin blade tool. Once the lid is raised you should have access to the problem device. It's possible it has become bent or misaligned. or wire connection apart or badly corroded. Electrical connections need to be cleaned to bright metal. Otherwise, replace the broken device and or switch.
May 07, 2015 | Kenmore Washing Machines
I can't get the cover off of my magic chef washer to change the lid assembly. It seems to be very different from the other instructional videos I've watched. thanks Brad
Hello Brad,
On that washer to access the lid switch the top come um from the catinet to replace the lid switch. To open and raise the top simply place a putty in the seam between the front of the top and cabinet about a 1/2 to 1 inch in from the corners and depress clips that hold top to cabinet then once they are depressed in lifr up the top
Aug 17, 2011 | Magic Chef CAV2000AWW Top Load Washer
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My Admiral washer will not spin.
Unplug the washer.
Insert a putty knife between the top lid and the front panel,where the top meets the front. About 2 inches in from each side are 2 clips that must be pressed inward to raise the lid.
Once the lid is raised,remove the 2 wires from the lid switch and jump them together with a small jumper wire.
Plug the washer in again and turn the dial to spin and turn it on.
If it spins,replace the lid switch.
Jan 17, 2010 | Washing Machines
Reads "OP" when lid is closed
Magnetic reed switch on left side below the gray rubber bumper, shown here...
Release two spring clips in front between main top and front panel using putty knife. Lift the main top and access the left and right door locks here.
To access and see if the magnet is in place, remove the dispenser from lid.
Gently pry the bottom of the plastic inner lid toward you then down. This will let you see if the magnet is in place on the right front corner of the inner lid.
Seems to be a common problem with this washer. Apparently, the lid isn’t completely watertight and allows water to get into this switch corroding the contacts and the wires.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 09, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer does not drain and spin without us slamming lid
It sounds like a defective lid switch. The switch is inside the washer main housing near the door/lid frame. You normally have to raise or open the top or front of the washer to access the switch. It can be tested for continuity using a multimeter or ohm meter to see if it is faulty. Hope this helped and best wishes.
Aug 07, 2009 | Washing Machines
Need to replace lid switch
what brand machine? whirlpool take off the cabinet and the switch is on the rhs under the lip
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The washing machine filled with water, put the soap in and then some towels, after I closed the lid and the machine stopped working.
sounds like lid switch went ..try raising lid and listening for click when closed ..even if it does click could still be switch there is a small fuse and contacts inside switch 3 screws along top of console to be removed and console will lean forward to allow access to switch
Sep 07, 2008 | Maytag Washing Machines
Replacing lid switch
me too...exact same washer and same do u fix it?
Apr 20, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
