I replaced the STK394-250 IC with the STK392-110. The convergence is now worse than ever and it seems like the vertical deflection is out. The vertical lines are straight but the horisontal lines are in a bow shape and the colors are not aligned. I entered the manual convergence mode and am able to move the cursor points but cannot adjust the lines. How do I straighten the horisontal lines and line up the colors? I tried the Auto focus with no effect.
  • 10,594 Answers
You need to put STK394-250 IC in tv to get correct convergence.
STK392-110 is different part and has different internal circuit.
Posted on Aug 26, 2010
Verticle wavy lines, worse when cold
hello,
This is a vertical deflection problem - possibly a bad capacitor, bad connection, flyback/pumpup diode, or other component. None of these should be very expensive (in a relative sort of way).
If the symptoms change - particularly if they become less severe - as the set warms up, a dried up electrolytic capacitor is most likely. If they get worse, it could be a bad semiconductor. Freeze spray or a heat gun may be useful in identifying the defective component.
It is often easiest to substitute a good capacitor for each electrolytic in the vertical output circuit. Look for bad connections (particularly to the deflection ports), then consider replacing the vertical output IC or transistor(s).
A missing power supply voltage, defective vertical output IC, or a component associated with it is likely bad. A bad connection or blown fusable resistor may be the cause of a missing power supply voltage.
The following are NOT possible: CRT, flyback (except possibly where it's the source for a missing voltage but this is more likely just a bad solder connection at a flyback pin), tuner where the controller is at fault - see the sections on these specific brands. I am just trying to think of really expensive parts that cannot possibly be at fault.
Hope this will help..
May 26, 2010 | Toshiba 42H81 42" Rear Projection...
On going Convergence Issue RCA R52WH73 Television
did you reflow the solder on the flyback and the vertical output IC?
Jun 12, 2009 | RCA R52WH73 Projection Television
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi wt-46809
the vertical deflection IC if defective will cause the protection circut not to let the tv power up ,it has a thermal protection circut as well
here is the vertical deflection IC # la78045
and here is a link for the NTE equivalent part and specifications and pin layout
http://www.nteinc.com/specs/7200to7299/pdf/nte7209.pdf WARNING if you heat up any component to long or with to hot of an iron you can dammage the component and or the thermal protection circut
but I believe you will also have to replace the flyback (high voltage transformer ) with wire giving to much voltage
Oct 11, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Mar 05, 2008 | Sharp Televison & Video
Vertical length
Hiii....
I think you should check the cap around ic vertical deflection.... and see if there is have adjustment point or not ?! if you not so sure try to replace the caps and the ic too....
I'm not sure because i dont have service/manual for this model......
Hope can help you...
Thank's
[Vrya]
Feb 25, 2008 | Zenith A25A23W 25" TV
PT47WX52F Convergence problem, 3-d look, green worse
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Horizontal line in the middle of the television
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits.
If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself.
U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
286 people viewed this question
Top Televison & Video Experts
