Question about Element Electronics FLX3220F 32 in. LCD TV
TV flashes green light and goes back to red when started. Replaced power suply BA71F0F01041. Still doing the same thing. I tried the power supply in an identical TV and it works. Not sure what to try next.
  • dontowne Aug 26, 2010
    Picture isn't coming on at all. The green power light flashes twice when power button is pressed and then goes back to red.
    Thanks for the quick replies. Will definitely recommend your support.
  • Element Elec... Master
  • 3,866 Answers
Sounds like your T-con board is going out on you, This has zero to do with the power supply. In fact when a T-con board goes out you will get lines and also a full picture of green and different colors, its rare that its a power supply.
let me know if you have questions
otherwise please do click the accept button for my efforts.
Posted on Aug 26, 2010
  • 2 more comments
  • Grand Canyon Tech
    Grand Canyon Tech Aug 26, 2010
    Ok unplug it plug it back in and see if it comes on please?
    if not you got a issue with the T-con, But i want to wait and see type of thing here before i speel the wroung beans lol
  • Grand Canyon Tech
    Two blink SOS is t-con my friend, please check that out
    OK. Which one of the boards is the T-con?
  • Grand Canyon Tech
    In short the Decoder,tuner driver my friend!!
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Red light flashes on tv but wont turn on
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Jun 07, 2012 | RCA Televison & Video
When i turn my tv on the red light goes to flashing green it comes on then immediatly it goes off but the light is on green... can you help
Tries tv unplug,replug it back about an hour later.The tv,now should reset itself back to factory setting.The tv should work now,not than the power supply board is dying,not giving the right voltage to the rest of the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | LG 42LG30 42 in. LCD HDTV
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
Turn on and few seconds goes off
The fan is cooling the power suply and geting power from it the power suply is going bad the relay is turning the tv off to proteckt it's self.
Nov 24, 2009 | Televison & Video
When I turn my tv on green powere light comes on and then goes off and starts flashing red
It is the capacitors on the power supply...take off the back of the tv and look at the mother board thing in the top left...There are "fuse" like things (capacitors) and the tops should be flat on them. If they are swollen, then it's just those that need replaced and not the whole power supply...Got ours fixed with 7 replaced for 100.00. The tv gets too hot and they "blow"... Hope this helps
Oct 28, 2009 | RCA L42WD22 42 in. LCD Television
Element Electronics FLX3220F 32 in. LCD TV Logo
292 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
