Question about Sony CDP-CX300 CD Player
Spin both directions theb display show table error
    Problem Solver:
  • 11 Answers
Usually CD rotates in the clockwise direction. Whenever you are using CD which your CD player cannot detect then CD is rejected and suddenly CD rotates in anticlockwise direction.
Also, If your player is older and your CD players laser head worn out then CD's which were played good previously cannot be played properly and then stop in middle, when this happens you can see CD rotating in anti direction.
Clean the laser head, with CD cleaner and do not use scratched CD's
Posted on Aug 27, 2010
2 Suggested Answers
projdoc
  • 2236 Answers
SOURCE: when power up table spin both directions theb
the sensor for the table cna't read the table movement. it's an optic sensor and it might be dirty or obstructed. you can open up the unit and blow out any dust with canned air. check the sensor for damage.
Posted on Dec 17, 2009
Why is there no sound output?
We canot help you without theb makew and model of whatever instrument you are having trouble with. However, the first step for any electronic device it to reinitalize it.
Feb 08, 2016 | Music
FURTHER INFO TO LAST QUESTION ... NO SPIN
it does not spin in 2 directions. are u mistaking it to spin both directions? because one direction is for wash the other for spin? u may have a slipping clutch? or bad motor coupler or worn belt
Feb 22, 2015 | Washing Machines
Lights flashing under spin cycles , and programes will not operate
Either the motor or the main control board (could be both) has a serious problem.
However, it can also occur if there are spikes in the mains and it upsets the control board.
Try clearing the error code table and reset the control board.
Turn the knob to the off position.
Wait 2 seconds.
Turn the knob to the 6 o'clock position.
Wait till the start light flashes.
Wait 2 seconds.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Release the spin button.
This should clear the error code table.
Turn the knob to off.
Turn on and try the machine again.
Try this a few times.
It should clear the fault code but if the control board or motor is still faulty, it will detect and show the code again.
Jun 15, 2011 | Washing Machines
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
I have a fav6800 maytag washer, I am getting a UC code. If the drain is blocked in someway will it give this message? the machine works fine till it comes to the rinse and spin and then error code comes...
What are the first to digits of your machines serial number? It will be 10 thru 17.
Did the machine bang around in Spin Cycle during the wash Cycle with the uC error code?
The FAV6800A and it’s sister FAV9800A LCD display version of the machine suffer from a chronic Dry/Rusted One-Way Roller clutch issue. See this Clutch repair post on this forum for clutch maintenance and or replacement and this post on another forum. Read how to check the failure of the One-Way Roller clutches to slip in the CCW/Spin direction at this post.
If you are just a bit handy you can do the maintenance or order a replacement from AZ they have the best price around $56. I will help you every step of the way…..Rich
Couple of links to the Service Manual and Sears Parts Direct for reference.
I’ll paste in how to check the Tub Displacement Sensor. I don’t feel that is the issue but is will give you a chance to go into Service Mode and check thru the lid for proper operation.
Tub Displacement Sensor Diagnostics check. This test is done with the washer lid raised see page 19 of the SM for the details.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine and not the cause of dC or uC unbalance errors……fix the clutch and your machine will be
J
Jan 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
When power up table spin both directions theb display show table error. Sonny cdp-cx355
Dec 17, 2009 | Sony MegaStorage CDP-CX355 300-Disc CD...
The jukebox powers up but the buttons wont work
Is this a CD player or 45RPM? Is the display lighted? What is the display showing? The answers to these questions will help narrow down the problem. For additional assistance please email Rod Stebelton, tech@wurlitzer-ohio.com.
Nov 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wont recognise any disk
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | Televison & Video
Sony CDP-CX300 CD Player Logo
278 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
