Need bass cones for wharfedale delta 90 speakers
I'm putting some on ebay this weekend
Posted on Sep 25, 2010
Fix a torn speaker cone?
If it is a woofer, you would probably fix it quite easy. If the speaker driver is used for both bass and midrange, you have a problem.
Fixing a speaker cone is depending on the material. If it is paper cone, it is very easy by using paper that you glue with wood glue (White water based glue) on to the cones rear side (for estetic reasons).
A midrange or bass/midrange driver is operating in frequencies where the cone starts to break up. Not torn apart, but the break up frequency is the frequency where the inner and outer part of the cone not longer follow each other in the same direction. These properties of a cone determine the sound of the speaker which is that type of speaker drivers "identity". Messing that identity up, you end up with a speaker that does not sound as the original one.
Remember that cross over network used to split up frequency ranges, not only are lowpass, bandpass, and highpass filter, but they also filter irregularities where the speaker driver is not longer providing a linear frequency response (Its characteristic sound).
If the cone is polypropylene, there isn't much glue that bite on that material.
May 02, 2016 | Audio Players & Recorders
Would like to know size of bass unit in Wharfedale Linton 3XP Speakers?
Take a ruler and measure across the face of the speaker frame or go to wharfedale's web site for that information.
Oct 29, 2014 | Audio Players & Recorders
How do i connect Wharfedale 9.5 speakers to onkyo HT- R538 home theatre system
Take a look at the setup procedure. Your Onkyo may allow you to select speaker size and distribution of bass, etc
Dec 26, 2012 | Wharfedale Audio Players & Recorders
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Ok..... I have some Wharfedale Modus 8s. My question is, is that the base speaker is crackling a bit. typically when you don't have enough power the tweeters will clip first and go out. perhaps i did...
Dunno how old they are, but I just had an 11-year old pair of woofers re-edged because the foam surround and the adhesive had deteriorated. Upon close inspection the foam surround was noticeably pulled away from the cone in a few spots. Unfortunately, if there is an age-related issue with materials beneath the surface that you can't see, you'd have to pull the driver to check it out.
It wasn't until I turned my bass up loud that anything sounded wrong, which precipitated looking for the culprit (quickly found).
Nov 08, 2010 | Wharfedale Modus One-Six Speaker
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
222 people viewed this question
 Grubhead
Grubhead
