Question about Acer AL1916B 19" LCD Monitor
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green settings but it isn't helping. When i click the "Auto" Button on the monitor to set it to the correct colour automatically i see the right colour for a split second on the monitor but it then re-verts to the previous Green tint version which i don't want.. How do i take off the green tint? is my computer monitor broken? ( Defiantly not my computer settings as I'm currently using a different monitor and its working fine )
  • radheshyam bhariya Oct 18, 2011
    I have got problem green tint with retrace line and high brightness in hp p1130 crt monitor.
    Sergeant:
  • 223 Answers
Sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Posted on Aug 26, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
Acer AL1916 monitor wont turn on
normally along the number keys are cymbals, you must look for one that is a wireless sign, then i think you must press a key with this key to enable it, normally its a fn key
Nov 29, 2009 | Acer AL1916W 19" LCD Monitor
I have an acer monitor model #al1916 when I turn it on it sstays on about 5 second and shut back down
First, check all electrolytic capacitors and replace those which are blown or rounded. Next, if when it shuts down the green LED also turns off, then
on the controller PCB there's tiny transistor-like chip U406. Remove it from the board and try to turn the monitor on. That's reset circuit, you may live without it.
Sep 05, 2009 | Acer AL1916W 19" LCD Monitor
Greenish screen
sometimes speaker magnets or any metallic device can cause this disturbance in this type of monitor. also, if you are using dvi, i would reset all video driver settings to default. this may correct this green tint you are seeing as well. reinstalling the monitor software could have a positive affect.
Feb 05, 2009 | Dell E196FP 19" LCD Monitor
Red tinting with the Acer LCD monitor AL1916
Amazingly enough my monitor did the same thing and while looking for the serial number the problem got resolved. Since I don't know exactly how it got fixed I will tell you what I did. I turned the monitor off, removed the power cord from the unit, turned the surge protector off and back on, placed the monitor face down on my chair to read the serial number, reconnected the power cord and turned the unit back on. The problem was fixed. Go figure.
Nov 16, 2008 | Acer AL1916W 19" LCD Monitor
Acer moniter model AL1916
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Oct 14, 2008 | Acer AL1917W LCD Monitor
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
330 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
