Question about Craftsman Garden
I HAVE A CRAFTSMAN 10 INCH BAND SAW MODEL NO 351.214000 I BROKE THE BLADE, AND GOT THE PROPER SIZE 70 1/2 3/8 I CAN'T KEEP THE BLADE ON THE BOTTOM PULLY...... IF THE BLADE IS LOOSE, IT WILL STAY IN THE MIDDLE,BUT WHEN I PUT THE PROPER TENSION AND ADJUST THE TRACKING IT COMES OFF THE PULLY FORWARD. IT SEEMS THAT THE BOTTOM PULLY NEEDS TRACKING TOO, BUT I DON'T THINK THERE'S AN ADJUSTMENT FOR THE BOTTOM PULLY. WHAT'S THE PROBLEM????
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Posted on Feb 26, 2009
  • 571 Answers
SOURCE: the chain adjuster screw is broken
If the housing itself is broken you will probably be better off buying a new or used say. As that part would be very expensive and you will still have a used saw.
Posted on Apr 07, 2009
steve_lima
  • 181 Answers
SOURCE: electric chain saw chain adjustment. How loose should it be?
the chain should not be sagging from bottom of bar.when you tighten the chain push the nose of saw up so that all of the slack is out of the chain.chain should snap back in the bar if you pull the chain up and let go.when i adjust a chain i push the saw forward to make the bar go up and stay there while i tighten the nuts.hope this helps, let me know
Posted on May 13, 2009
SOURCE: HOMELITE Textron Chain Saw, wont stay running properly.
The preset is to turn them all the way in (Don't tighten them hard or you will damage the needle) and then back each out 1 1/2 turns. This will get you started. You can then run it at full throttle and turn the high speed jet in untill you hear a change in the RPM. Then turn it out untill you hear the same. Find the happy medium.
Posted on May 15, 2009
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
What size blade for a craftsman bandsaw 113247110?
Your band saw uses 10" band saw tires and a 63 1/2" band saw blade. . Get band saw blades on sawblade.com
Sep 03, 2014 | Saws
How to replace blade on craftsman 10 inch ban
Here's a good blog about changing band saw blade. Or you may also want to watch instructional videos. How to Properly Install Band Saw Blade
Aug 28, 2014 | Saws
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
Can I use Craftsman 99-3/4 in. Band Saw Blades - 3 pk. on my craftsman 14" bandsaw #124.32607
I think you need a specialist to answer your questions and can give you some options. You may want to give a call to www.sawblade.com . You can contact this 201-450-9810 or visit to their website . Hope that helps.
Dec 27, 2012 | Saws
I am looking for a manual for a Craftsman 10" Band Saw Model No. 103.0101
I have a 10" table top bandsaw and i need to replace the drive belt. Can't find a manual for this and don't know the size of the belt.
Aug 14, 2010 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Straight cutting with rip fence
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Garden Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
