I own a Memorex DVD player, model MVD2030 which hasn't been used for 6 years (when I moved). Tried to set it up today and find the "open/close" button does not function. Any ideas on how to resolve this problem?
  • 32 Answers
Its not problem at all.
if you have an old stereo or tv set you can use one of the small push botton to replace it.
you will need screw drivers, solder, suction and some patience to do the job. that is if the botton is making bad contact.
the problem can be a bad driving IC.
try to open the casing, locate the open/close motor, turn it manually to fully open tray. plug the set into power and try to close the tray. does this happen and still the tray wont open with the botton, then your driving IC is bad. i dont know if you can change the IC, its small and maybe and SMD.
Posted on Aug 30, 2010
I forgot the password to our dvd player. It is a Memorex MVD 2037 DVD player. Any suggestions?
The default password is 1234.
or..
Memorex MVD 2037 & Memorex MVD 2051
1. Turn on the Player.
2. Press the Open / Close button, (keep tray open)
3. Press the Clear button.
4. Press 1,3,6,9.
5. Press the Region you want, 0 for Region free.1 for Region 1 and so on
6. Turn your player off and then back on.
N.B if the hack does not work you may find you have to ommit step 3 and try again.so the hack will be
1.Turn on the Player
2.Press the Open / Close button , (keep tray open)
3.Press 1,3,6,9
4.Press the button for the Region you want, 0 for Region free, 1 for Region 1 and so on.
5.Turn your player off and then back on.
Alex
Feb 01, 2011 | Memorex MVD2037
Memorex mvd2040 showing wrong region
HELLO
Try this hack - it may work for you.
Turn on the Player.
Press the Open/Close button.
Press 1 3 6 9.
Press the Region you want or 0 for Region free.
Turn your player off then on again.
I understand if it is a model "B", it might not.
GOOD LUCK WITH IT ANYWAY! (:-)
Sep 09, 2009 | Memorex Televison & Video
Put lens cleaner in my memorex mvd2016 and it still says "wrong disk"
Had the same thing. Tried opening and closing a number of times- powered on and off a few times- used a lens cleaner- nothing.
Unplugged the power cord from the wall, plugged it back in- BINGO- it works. For now.
Aug 14, 2009 | Memorex MVD2040 DVD Player
Won't play dvds, always says open then shuts off
If there is a AV switch on the right side of the player, move it to the opposite position. If that doesn't work, or you don't have an AV switch on that model, the unit needs to be replaced. Call Memorex at 800-919-3647 for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further
Aug 04, 2009 | Memorex MVDP1072 Portable DVD Player
Memorex MVD2050 problem with buttons on machine
Hi..
No offense but Memorex is junk.
Get you money back and try walmart or someone else
Dec 26, 2008 | Memorex MVD2050-BLK DVD Player
Won't play, says open even when the lid is closed.
Well , from your bumping experiences , I would say the latch/hook/switch that tells the player that its lid is closed is loose.Carefully close your lid and see the parts that touch and you will find the latch/hook/switch.Manually play with it (or tape it down!) for a quick fix.For a more permament fix you might have to open it and fashion (or buy) a new switch.
Dec 18, 2008 | Televison & Video
Memorex MVD 2042 DVD Player ''Key Lock on''
mt memorex dvd player says ``key lock on´´ and i don't know how to quit that and i can't opened with the remot control
Help please!!!!!
Nov 17, 2008 | Memorex MVD2037
I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
May 16, 2008 | Memorex MVD2022 DVD Player
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
Universal remote code needed
If you have tried all the codes the manual has it may be the remote does not support your model. Here is a lin to a remote I think will work on ebay:
http://cgi.ebay.com/Memorex-DVD-remote-control-MVD-2022-MVD-2042_W0QQitemZ280186652283QQihZ018QQcategoryZ91388QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You also can try another universal reote brand that might support your unit. Hope this helps.
Dec 27, 2007 | Memorex MVD2027 DVD Player
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
