Question about Yamaha DSP-AX1 10-Channel Amplifier
My yamaha DSP AX1 amp does not work when audio is connected via optical or coaxial any suggestions how to correct this. no sound comes from any speaker except the subwoofer.
  • Scott Frye
    Scott Frye Sep 01, 2010
    Do you have a manuals for it?
    If not , try the Yamaha consumer website
  • 3 Answers
Hi there i had the same stress lol it was a sticky speaker swich put some phono lead from main pre out 2 main in and center out then in thats should be it
Posted on Jan 03, 2011
  • 53 Answers
Are all the speakers turned off (set to None) in the speaker menu.(except the sub)?
2 channel direct analog stereo may still work, but any surround modes will use the speaker settings and the full DSP digital section.
Check also the input mode isn't incorrect - although if the sub is wired correctly and gives sound this can't be whats wrong.
Posted on Sep 04, 2010
2 Suggested Answers
  • 236 Answers
SOURCE: Yamaha dsp-A1000 5 ch Amp
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
Posted on Aug 04, 2008
So i just bought a Yamaha Stereo Reciever The model is RX-V377 I have it hooked up to my stereo system correctly and it sounds great. But the only thing I have managed to hear out of my speakers on the...
The unit has five HDMI sockets, the first on the far left (looking at the back) is for sending video and and audio out to the TV. All the others are inputs. If you want to hear the TV via the unit and speakers you must connect via the one of the four other HDMI. Or if your TV has optical or coaxial output you can connect it via those settings. It will also pass Dolby Digital signals to your Receiver if the TV can do so.
Jul 01, 2017 | Yamaha Audio Players & Recorders
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
YAMAHA DSP-AX1 SOUND CUTTING IN AND OUT OF FRONT CENTRE CHANEL
Check if the sound comes from a digital source like an optical cable or the one that generally the color is orange (not the common red and white, nor the yellow terminals) then check also if this ocurr with certain music. Let me know
Jan 18, 2014 | Yamaha DSP-A1000 5-Channel Amplifier
The sound of the LEFT MAIN Cannel disappears on my YAMAHA DSP AX-1
The fact that sound appears at max volume means that it is getting past and through the pre-amp stage. So it would appear to be in the main power amp stage the problem. It would depend what drives the channel, but if it's transistor driven I would suspect one of them.
Oct 31, 2012 | Yamaha DSP-AX1 10-Channel Amplifier
Yamaha DSP-AX1 ,. When turning on it only stays on about 4-5 sec. then shut off. Bob
Is this new equipment or a new problem on working equipment?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-DSP-AX1-Amps-manual/id/319bh827/t/2/
See Troubleshooting Page 79
Impedance Selector in between settings
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 07, 2011 | Yamaha DSP-AX1 10-Channel Amplifier
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Sep 26, 2009 | Yamaha Rx-v565 Receiver
Audio thump on changing any parameter
My bet is a faulty electrolytic capacitor! Don't know which. but would look around the circuit of those stages.
May 30, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Jan 19, 2009 | Sony STR-DG510 Receiver
Yamaha DSP-AX1 10-Channel Amplifier Logo
305 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
