Question about Linksys Wireless-G Broadband Router
My wireless does not work in every room in my home? It will not connect when I'm in my bedroom. If I try to connect it asks for a passphrase or security?
  • 3,289 Answers
Depending on the location of the router, the home's construction and other variables - it is very likely that you will not be able to connect from every room. You could purchase an upgraded antenna that will increase your range - look for antennas that are compatible with your particular router.
You're being asked for a security / passphrase in some rooms because you're probably connecting to a neighbor's secured wireless router. Without the proper credentials, you won't get in.
You could install an Access Point, or other wireless device if the extended range antennas don't work well enough for you, to provide coverage where you want it. You might also try relocating the router to a location in the middle of the furthest points you want to get access.
Please rate this reply - good luck!
Posted on Aug 26, 2010
My new laptop doesn't work
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 12, 2012 | Samsung Computers & Internet
Hi, I'm having problems connecting to the router (Virgin) to my bedroom from lost of signal strength, so i brought Sitecom Wireless Range Extender 300N to boast the signal. I've installed the Range...
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Mar 21, 2011 | Computers & Internet
When trying to connect to wireless network at home it asks for router pin then tries to set up new network. I want to connect to exsisting network
My friend,
Where it says for a pin .there is option below that screen "I want to enter passphrase"
Please select the option and enter your wireless network key.
You will be connected to the existing network when you will enter the key.
Regards:-
Amit
Jan 21, 2011 | Linksys Computers & Internet
Got a home network with a cable modem, router in my living room, and a laptop and desktop in bedrooms. Router is connected along with the cable modem in the living room pc. Mcafee firewall said that i had...
the problem is is your pc has a built in modem???model of laptop and model of desktop???
contact me here if you want some help..stormblade002@yahoo.com
Feb 06, 2010 | Computers & Internet
I want to connect my iPhone 3G to my home wireless network using WRT54GS I have found the wireless security tab with the passphrase and Key 1. My iphone ask for a password. I have tried different...
The security type on the router is WEP.
In this case you will need to use the key 1. that will be the network key for your wireless network.
Check just next to the wireless security tab , you will see wireless MAC filter. It must be disabled. If it is Enabled then disable it and save the settings.
When you try to connect using the WEP key 1 , do you get any error message ?
If you get any error then try $ sign and wep key1.
Click Here for more info
Nov 23, 2009 | Computers & Internet
Trying to set up laptop internet connection on vista keeps asking for passphrase i do not have this information
the passphrase is a security that is attached to the wireless router you are using, you can contact the person that configured the router to give you the passphrase or you can reset the router to factory setting by pressing the reset botton for 5seconds
Oct 31, 2009 | Toshiba Satellite A105 Notebook
Problems with wireless connection - gateway notebook
Might be several things, but perhaps start with checking for any driver updates that might be available.
Feb 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless Troubles with 2wire
you need to check the wireless encryption for your 2wire modem..
Sep 20, 2008 | 2wire 2700HG-B Router (2700HGB)
Connecting belkin router
Hi!
How far are you away from the router to the bedroom?
What do you mean by "bedroom system"? Is it a wireless computer?
Apr 13, 2008 | Belkin (F5D5231-4) Router
Belkin wireless g problem
well..that passphrase is from a secure connection..you might need to get a new set of drivers, and re install that router.
go here for those drivers(look for Belkin router)
Mar 25, 2008 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
175 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
