Question about True Deli-Cases TSID-72-2-L Refrigerator
How long does a deli case compressor run for?
  • True Master
  • 43,501 Answers
Over night it should run half the time... during times of use, it may continuosly run...
heatman101
Posted on Aug 28, 2010
How much it cost to replace a compressor on True Deli-Cases TSID-72-l2
Your looking at a Job that takes about 4 to 5 Hours of labor. Reclaim machine,Vacuum pump, Torch, Silver Solder, Freon, Nitrogen,Liquid line drier, Possible suction line drier if it was a shorted compressor windings. New start components. and then maybe a cap tube depending on what caused the compressor to fail. So with that said you can expect to spend $1500 to $2300.
May 09, 2014 | Freezers
I have a Beverage-Air 4ft deli case unit powers on and runs but the pressure switch shuts unit down after running a few mins and then unit will start right back up run a few min and then shut off again ...
This could be caused by a defective fan motor, defrost problem, a Freon leak or a defective pressure switch. Does your model have a model number listed somewhere? I am here should you need me, Thanks John Tripp Appliance 911
Apr 08, 2014 | Refrigerators
My deli cooler line is treezing back to the compressor
2 things to check. One is the evaporator fan or a dirt build up on the coil. two is the freon level of the system.
Mar 17, 2013 | Air Tools & Compressors
Deli case icing up at evaporator inlet
Most deli units are gravity cooling units and it is normal for the evaporator to be iced up if your unit has fans it still is not unusual, the ice will melt when the unit cycles off. If the evaporator is only iced up on one end, you are low on freon.
Feb 26, 2013 | True Deli-Cases TSID-48-2-L Refrigerator
The compressor is making a loud noise
If you are sure the noise is coming from the compressor.You need to call a tech. to check the unit out.
Jan 31, 2012 | True Deli-Cases TSID-72-4-L Refrigerator
Compressor / Fan not coming on
if there is 2 wires on it, turn all the way on then test continuity across terminals with wires diconnected
Apr 24, 2010 | True Deli-Cases TSID-48-4-L Refrigerator
Problem with the plastic connector for the defrost water collecti
True.com if its not that old a good service guy should be able to configure something.
Jul 03, 2009 | True Deli-Cases TSID-72-4-L Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
True Deli-Cases TSID-72-2-L Refrigerator Logo
77 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
