Question about Ovens
Creda Solarglow Plus Cooker Twin Grill Regulator Model 48349
I have a Diamond H 48ER101C1P Replacement Energy Regulator to replace a Strix ( numbers on Strix switch are: T 125 A4010
13A5 40 346 )
Cooker model: Creda Solarglow Plus 48349
The Diamond Regulator is to replace the dual grill regulator.
Can I use this regulator with the linkwire from P1 to S1 ?
Many Thanks
Siggi
3 Suggested Answers
SOURCE: Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Posted on Dec 30, 2009
  • 11 Answers
SOURCE: I have received an EGO
Unfortunately the EGO 50.52076.070 is not the correct replacement for a Diamond H 31ER1HT as it does not have a live pilot connection.
Regards Murv...
Posted on Jan 14, 2011
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
My creda cooker lost power when I turned on the grill but did not trip the main fuse and there is still power at the main swtch
Is it a built-in model? If it is then there is sometimes a wall plug in a cupboard that may have a fuse in it.
Feb 01, 2016 | Creda Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
I have received an EGO 50.52076.070 energy regulator as a replacement for an old Diamond H 31ER1HT, included was a wiring diagram showing the following connections for the replacement, P1 : Line. ...
Regards Murv...
Dec 16, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
Creda cooker grill not working,elements replaced, still not working. any suggestions?
Could possibly be grill selector switch faulty, or, depending on the model, it is sometimes caused by a faulty main oven door switch.
Please rate my solution.
Thanks.
Jul 29, 2009 | Ovens
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Sep 08, 2007 | Ovens
Ovens Logo
402 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
