Question about Nintendo GameCube Console
The power light on my gamecube will come on when i push the power button and the fan will run but nothing will show up on the screen or the disk wont spin. i have nothing but the power adapter and the red yellow white plugged in
    President:
  • 894 Answers
Well I thin that it might be broken then. Also a repair will need to be settedup by the Nintendo repair place. 1 800 255-3700
Posted on Aug 25, 2011
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Will not reboot, at all. i power it on, the power light comes on, the dvd drive spins a few times and then nothing.. the bios screen wont even show. please help.
try removing the ram from the bottom of the case first and take the disk out. power on the unit. if you get a bios screen there is a good chance you have some bad ram. let me know what you get from there
Jul 12, 2009 | Gateway MT3422 RTL Notebook
A gamecube game is stuck in wii... Please help...
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show Step by Steppictures to fix the problems yourself without any technical knowledge.
Jan 02, 2009 | Nintendo Wii Console
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Won't boot up, Fans are on non-stop
Open up the pc with power off. After cleaning with a blowing or sucking device, gently press on the connections and plug-in devices. Retry.
If no avail, the power supply or the motherboard may have bit the dust. U can get them repaired or replaced.... or save the HD and buy a another pc and add the old HD as a data disk.
May 11, 2008 | Gateway GT5056 PC Desktop
Gamecube - blank screen, disc wont spin, power light and fan work.
Troubleshooting - Power
No Power
Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
If this fails, try resetting the AC adapter.
Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
Power Light Flashes
If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Dec 07, 2007 | Nintendo GameCube Console
Start up...it wont
have you tried cleaning the game disk? rub it on a soft cloth.
Oct 25, 2007 | Nintendo GameCube Console
Nintendo GameCube Console Logo
94 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
