Question about Honda Pressure Washer PSI 3000
I live in the naples fl. area .--where can i get my comet axd 3030 pump rebuilt and what is the cost?
  • 3,740 Answers
These AXD pumps usually do not require a rebuilding process. What happens is the unloader / bypass valve gets stuck and you do not get any output pressure. What you can do is tip you pressure washer so that the input and output fittings are vertical and actually dump oil into the water supply hole. (3 oz at least) Slowly pull the recoil (ign off) and add a bit more oil and let it sit overnight. Then the next day once again pull the recoil through and let it sit another 10 minutes. Then connect all hoses (Purge the air in the garden hose) BEFORE connecting the main water supply and start the unit then running at MAX SPEED rapidly fan the wand trigger. What your doing is cycling the unloader valve. Do not do this for more than 2 minutes if the pressure does not suddenly start. IF the pressure builds continue at lease another 30 rapid cycles of the wand trigger.
I lost count on just how many pressure washers I have brought back to a good working service life by just doing the above. I do know it is a substantial number.
Give this a try before you go off on the need to rebuild the pump avenue.
Posted on Aug 26, 2010
Who has axd 3020 oil in isle of man
30 weight non detergent works in most pressure washer pumps. available at most auto parts stores.
Jan 08, 2014 | Comet GXD2527G Pressure Washer Pump
Comet axd 3020 will not build pressure
junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available.
The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure.
parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
Oct 31, 2013 | Comet Garden
Comet pressure washer is pulsating
check your check valves.
or one of the wobble plate pistons is not working right ( broken, broken spring etc)
Aug 17, 2013 | Comet AXD 3020 G Pressure Washer Pump
Had transmission rebuilt on my 2003 honda odyssey car drove back to naples fl from miami its the next day and the car wont start hit gas and nothing
If it isnt turning over you may just have a bad battery connection or ground.They may have taken your starter out when they rebuilt the trans and maybe a wire is loose or came off.
Mar 20, 2013 | 2003 Honda Odyssey
What type of oil goes in a comet axd 3020 pressure washer pump?
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Jul 14, 2010 | Comet GXD2527G Pressure Washer Pump
I need a police frequency book naples fl
Don't buy a book -- for a no-cost comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 28, 2010 | Uniden BC72XLT Handheld Scanner
Broken need repair place in Naples Fl Binoculars are broken lens not working please help me find a repair shop near me in Naples Fl
Check Yellowpages for a camera repair shop. Often they can really help as optics are a part of their game.
Jul 13, 2009 | Optics
Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Upper & lower Ford Ranger ball joints replacement
that sounds pretty high, I had those replaced on my 99 ranger XLT and it only cost me $400.oo, in Naples, FL. Id definately shop around.
Dec 21, 2008 | 1999 Ford Ranger SuperCab
Connect an external flash
For external flash use with the C-3030 Zoom, you will need the appropriate flash cable and grip. Please use the following as a reference: Exclusive Grip FL-BK01 - used to mount external flash to the C-3030/C-3000 Bracket Cable FL-CB01 - this cable is required for the dedicated FL-40 flash PC Flash Cable FL-CB04 - this cable is required for any "other" external flash/strobe use that connects with PC sync cable
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Honda Pressure Washer PSI 3000 Logo
174 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
