Question about Carrier 38CKC030 Air Conditioner
I have a carrier 38ckc030 air conditioner. the unit outside is not turning on. it sounds like it wants to and if you manually spin the fan it will slowly build up speed, but the air coming into the house is ambient temp. I searched and it sounds like the startup capacitor might be the culprit. Any advice?
  • 139 Answers
You are right replace the compressor/fan capacitor this helps compressor/ fan start its the round silver or oval part in the condensor ..let me know ..good luck/joe/
Posted on Aug 26, 2010
No cool air is coming out of vents. Checked Filters OK, Cruited breakers OK, vents OK not blocked. Could it be low on freon and compressor froze up and I should wait for ice to melt than possibly get...
Yes let the ice melt on the evap coil and the outside line. You either have a low charge or you might check your filter dryer on the outside lines this could be stopped up. you will will have a temp drop across the filter if it is stopped up. If not it is possible to be low on charge. Is the inside fan turning and turning the right direction. If the inside fan is not turning it will cause the evap coil to freeze up.
Jul 27, 2011 | Carrier 38CKC030 Air Conditioner
Furnace stopped blowing cold. 'Stat works, blower works. Went outside, condensing unit fan does not run, motor is excessively hot to the touch. Fan blades spin freely. I pulled the disconnect and...
Hi!!
Replace motor fan and capacitor, it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300+. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
Aug 13, 2010 | Carrier 38CKC030 Air Conditioner
Air condition unit of sufficient size??
You currently own a 2.5 ton AC Unit
500 square feet equals a ton of cooling/ you need a 3.5 ton unit.
If your home is well insulated, good windows and doors and pretty good
shade that covers your house, then I can see a 3ton unit cooling your
house.
Thats another 6,000 btus you do not have and that is a best case for a
energy effcient home.
Jul 07, 2010 | Carrier 38CKC030 Air Conditioner
My Carrier air conditioner condenser unit model 38CKC030 doesn’t always start.
Check the contactor........it is possible the contacts are wearing..........the contactor is considered a wear-n-tear item.
Jul 03, 2010 | Carrier 38CKC030 Air Conditioner
Turned unit on for first time, it will not kick on
does the indoor fan blow? If it does you are getting the 24 volts from the thermostat to the ouside contactor need to check your contactor in the oustide unit this is what kicks on the compressor it take the 24 volts and goes to 230 volts to run the compressor and condensor fan. check your schematic for the placement of the contactor.
Jun 04, 2010 | Carrier 38CKC030 Air Conditioner
38cks is blowing air but it's not cooling
First thing, are the filters clean? If so then you have lost some gas from the system and need to find and repair the leak, and put in correct gas charge.
May 21, 2010 | Carrier 38CKC030 Air Conditioner
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
Carrier 38CKC030 Air Conditioner Logo
202 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
