Question about Lenovo IdeaPad Y510 Notebook
I need to replace a CMOS battery for a Lenovo Y510. Need disassembly instructions. Thanks!
  • 384 Answers
Hi There and Welcome to Fixya!
Replacing CMOS battery for a laptop computer is quite difficult and often requires a trained (brand) professional and the necessary tools to get it done. With this, I would highly recommend for you to contact their helpdesk support and see if they can offer you other options :
Lenovo Support
Pretty much, this computer is already out of warranty so if you would decide to send it in to their repair center, they should be able to provide you the overhead cost estimate at the very least.
Similarly, I have included the user's manual specifically for this product and see if it can help you:
Y510 manual
Thank you for using FixYa.
Posted on Mar 12, 2011
Locate CMOS battery Lenovo Y570
It should be on your motherboard. You have to carefully disassemble you lap top .. Removing all Usb,Battery, and external connections.
U need a small screw driver to take it apart.
Leave your computer on for a day. If your need specifics let me know!
May 07, 2012 | Lenovo IdeaPad Y510 Notebook
How do I replace a Lenovo Y510 CMOS battery
http://consumerdl.lenovo.com.cn/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/Y510/Y510%20User%27s%20Guide.pdf
Try this link .pdf manual. If you unscrew the plates look underneath after taking out the screws for the plates. it should not be that hard to see it. John
Apr 19, 2012 | Lenovo IdeaPad Y510 Notebook
How do I replace a y510 cmos battery
Locate your CMOS battery
Caution: When inside your computer make sure you're aware of ESD and all it's potential dangers.
cmos.jpgOpen the computer case and find the battery on the computermotherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from. The part number for this battery for most computers is CR2032.
Additional buying information can be found on our battery buying tips page.
Removing the battery
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and resetting the CMOS values to the defaults. After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
How do i remove idealpad y510 bios password
Make sure your laptop is fully shutdown plug removed then remove your laptop battery,and there should be a small cmos battery which is about the shape of a watch battery, remove it for about 30minutes and then put it in back again then you will have to go into bios and change the system time to current date and that should clear the password and allow your computer to start, if not your might have to open up your laptop and get to the mother board to find the cmos battery , and remove from there if this is the case of which you have to take it apart i suggest you take the machine to you local pc repair man. i hope i helped.
Jul 18, 2011 | Lenovo IdeaPad Y510 Notebook
I am looking for lenovo ideapad y510 LCD screen replacement guide. My Screen is cracked
Hi 284607,
I see you need assistance on replacing the LCD screen on your Lenovo Y510 Laptop.
I have a link here that you can got do and download the information on how to replace the LCD screen on your Lenovo Y510 machine but then again just a disclaimer, any damages that may occur during the replacement Lenovo will not be held Liable.
See link for the Details:
LCD replacement Y510
I hope that this helps.
Have a nice day,
mvincentc
May 26, 2011 | Lenovo IdeaPad Y510 Notebook
Password bios lenovo y510
To reset the BIOS password read the information from this link.
In case of your Lenovo laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Feb 09, 2011 | Lenovo IdeaPad Y510 Notebook
Is there an available component level service manual for the Lenovo Ideapad Y510? I am trying to replace the lower case shell, but I'm having difficulty releasing the shell due to all the external...
Hi xuaom,
i see that you have a Y510 Laptop and that you need info on reoving or repacing your buttom casing.
You will need to remove mostly everything that can be found underneath the laptop one by one to be able to remove the wholw buttom case on this issue below will be screen shots of the step by step FRU part that needs to be removed for the buttom case removal.
Folow the steps below:
I hope that this will be of help regarding your case on replacing your buttom casing, have a nice day
Dec 05, 2010 | Lenovo IdeaPad Y510 Notebook
I have aY510 Lenovo Laptop.Someone Protect its hdd and setup through a password.How did I clear that password from CMOS
you can try to removed the CMOS battery,but its not 100% sure that it will be reset since theres no way for you to reset it,but some area ble to reset it bu uninstalling and reinstalling the battery
Jul 10, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo IdeaPad Y510 Notebook Logo
598 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
