Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
When door is opened a puddle of water comes out . Where can I get a solution
  • Miele Master
  • 2,605 Answers
Welcome to Fixya.
The issue is likely just the blower and housing drain hose blocked with "dirt" from time & use.
First things first...**turn off the power via the breaker at your home service panel...safety first**
Yes, you will need to take the door panel off ( watch those edges they are VERY sharp ) and unfasten the control panel as well, the screw`s are around the perimeter of the door facing the dishwasher tub opening.
Once you have the panel off, you will then unscrew the round part surrounding the vent fan inside the door ( it turns about 1/4 turn counter-clockwise ) the fan motor assembly can be pulled off the door and cleaned out.
You should now remove the small rubber drain line from the fan to the tub which is routed inside the door panel & clean it out as it too gets plugged hence, not allowing the condensation to run back into the tub to be pumped out so when you open the door it pours onto your floor.
Hope you find that helpful. Let me know how you make out or if you require further assistance.
Thanks for visiting "FixYa" for your repair questions. Please take a moment and rate the solution provided here for you.
Good luck.
Macmarkus :)
Posted on Aug 26, 2010
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Puddle underneath fridge on occasion--tube coming down seems ok
This happens when the water from the defrost cycle exceeds the capacity of the pan under the fridge. The amount of water depends upon the door traffic (how many times opened in the day) humidity, and believe it or not, the door seals. If the doors to not seal or close properly, it will allow air, and the humidity that it carries, into the box, and that means more defrost water. You might also check the pan for physical damage that may make it leak.
Feb 02, 2010 | LG Bottom Freezer Refrigerator w/ Swing...
Puddles after rain, overheating light comes on when starting out
If you have a sunroof, your drains might be clogged. Open the front doors and look for a rubber spout pointing down at a 45* angle. Milk it a littleand water might come out. I cut mine to open it up a bit so this wouldn"t happen again.
Red warning light?? With the car cold fill the coolant res. so the level is in between the min and max lines.
Dec 18, 2009 | 2000 Volkswagen Beetle
Puddle appears in washer after clothes have been removed.
This sounds like a check valve for the drain hose has failed. This check valve is in the pump discharge port and prevents water left in the hose from draining back into the tub.
Charlie
Sep 09, 2009 | LG WM2301H Washer
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Jun 30, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
112 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
