Question about Thermos QuickSet 462836203 (LP) Grill
What I think is the "heat plate" melted or disintegrated on my Thermos 14000 Quickset grill, 461733803. Any ideas on how to replace it and prevent this in the future?
4 Suggested Answers
SOURCE: thermos grill-to-go.
found thermos website which I was unable to do previously. Thank you.
Posted on Jan 31, 2009
  • 30 Answers
SOURCE: a burner knob somehow melted off and now when I
You may have a blockage in the tubes connected to your gas valve. It could be a spider web.
The burners may not be connected to the valve properly.
It could be an overfilled propane tank, and the overfill protection kicked in.
It could be a bad regulator.
Posted on Mar 10, 2010
SOURCE: i have a thermos grill 2 go model # 4656110 and im
Cadial, I would be interested in two plates if you still have any left. I have two of these grills and I love them, I've just worn the plates out.
Posted on Jul 03, 2010
I need new grates and heat deflector?
If you want to purchase the parts online this it the best place to shop. They have a large selection of Thermos grill parts.
http://www.clagrills.com/grillparts/thermos/thermos-grill-parts-home.htm
Mar 30, 2011 | Thermos 6000 Traditional Grill
We just got a new propane tank and connected it and propane is not coming through
I'll assume you had it purged of air before you had it filled, right? A full 20lb tank should weigh about 35-38 lbs. If so try this: Leave the tank valve closed for a few minutes. Then open the tank valve very slowly. It may have a built-in excess flow valve in the hose that is checking closed and preventing you from getting gas. See if that helps.
May 12, 2010 | Thermos QuickSet 462836203 (LP) Grill
Where is the model number?
Model # is usually on a small metal plate fastened to one of the legs.
Apr 29, 2010 | Thermos QuickSet 462836203 (LP) Grill
Change the igniter on a thermos bbq
You may not have to change the igniter. It works like a spark plug (passing a small spark from an electrode (a small wire sticking from the bottom of the ceramic tube at the lower end of the igniter) to a metal plate positioned close to the tip. If the plate gets covered with soot or grease from cooking it won't work. Try cleaning the plate and bending it closer to the igniter tip. If the igniter is really bad and needs replacement, you can get a new one at most hardware stores. Installation is very easy.
Apr 22, 2010 | Thermos Stainless Steel Gas Grill
Disconnect and reconnect hand tight, open slowly, if this doesn't do the trick than tank valve is bad. Another thing that could be bad is your regulator, but I would start with tank first is grill worked before new tank.
Mar 21, 2010 | Thermos QuickSet 462836203 (LP) Grill
What keeps the rubber pads on the cover from melting when the cover is down. just bought it
enough metal to disperse the heat and a lid that is not sealed completely, letting out extra heat. and a certain type of rubber. i've had one for 4 years and it hasn't even come close to melting yet.
Jul 13, 2009 | Thermos Grill2Go Gas Grill 4656110
Flame problem
check the holes the flames come out of, they may be clogged, you may need to clean with a wire brush, if rusty then replace the burners. easy to replace
Sep 25, 2008 | Thermos QuickSet 462836203 (LP) Grill
Thermos QuickSet 462836203 (LP) Grill Logo
Top Thermos Grilling Experts
paulcarew
jdthefixer
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
