Pleae help.i tried to re-boot my laptop. however i fear my product recovery disc is damaged. i think i have wiped the hard drive but have no way of re-loadin windows. when i switch on i get a couple of lines of jargon the last of which says. invalid partition table. its a toshiba satellite p10 its about 8 years old. please please can you help. Katie.
    Genius:
  • 2,785 Answers
First of all you should have a bootable disk then only we can help
Posted on May 08, 2008
Cannot boot from cd rom on compaq evo d310v, i have lost all disks but have the product key if it makes a difference. So what i wanted to do was wipe the hard drive with dariks boot and nook then inst
Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Apr 21, 2013 | Compaq Evo D310v PC Desktop
How do i get a recovery disk for RV510
hi Jackn.
thats not good,was your laptop on at the time?
if it was you might have damaged something on the mother board.
lets hop you have not.
you can try the recovery disc but it should ask you if you want to wipe it clean.
you ask in your question,how do i get a recovery disk,then you go on to say you have one?
depending on how much you spilt and how quick you go to it,you might have to have it opened up to make sure it has dried out.
i think trying to do a recovery before you check its all dry in there is not worth the risk.
if you do open it up your self,get a hair dryer and try and dry it that way,
coffee is one of the worst things you could spill on a laptop.
Dec 08, 2017 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
HP PAVILION2945SE RECOVERY SOFTWARE VISTA 64 BIT
If the computer can still boot into Windows, you have the option to create discs using the HP recovery manager.
If the computer's hard drive is still functioning, press F11 on boot to enter the Recovery Manager interface.
If the hard drive has crashed, go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2100&lc=en&cc=us&dlc=en&sw_lang=&product=3747194#N509 and select recovery media to order the discs from HP.
Mar 05, 2011 | Computers & Internet
I just purchased a Hp notebook dv2214us from an auction but everything was wiped clean off the hard drive due to California Law. I completed a self test off the Bios and everything passed. I just recently...
did you go into the bios and change the boot order to boot to the cd rom first? Then it should boot to the disc. Otherwise you may want to use any xp/vista disc do the install dont insert a cd key then once windows boots up then put the disc in and try a recovery.
Thanks,
Lee
Feb 07, 2011 | HP Pavilion dv2214us Notebook
Laptop wont start up just says a disc read error has occured, press Ctrl+Alt+Del to restart but when I do this I just keep getting the same message
Two possibilities are involved. 1) The hare drive is not responding correctly. This could result from a loose cable (needs to be connected to the motherboard and the drive) or a damaged drive (either from damage to the disc or lost boot information).
2) A non-boot disc is being accessed in the boot sequence. This could be a CD/DVD in the optical drive, a floppy disc in that drive (older laptops) or a USB connected drive (either a thumb drive or a regular external disc).
The second issue is easy to solve, disconnect/remove any other media. Then try to boot. Alternatively, on most Windows machines, you can press F12 to choose the boot sequence. However, you need to press the button between the POST (power on self test) and the loading of Windows. For me, this can take several attempts.
For the first, the options depend on your skill/willingness to open the computer. One option is to use a Live CD (a bootable disc) to see the status of the hard drive. Use the F12 sequence if needed to boot from the disc. (The live cd could be a Windows Recovery/Install disc.)
To save files from the disc, you can either use a UNIX Live CD and an other drive (an external optical R/W drive or hard drive) or remove the disc completely and connect it to another computer. For this second option, use an IDE/SATA/USB dongle, a laptop hard drive enclosure or hard drive dock. The dock will work with a SATA drive; disc enclosures need to be selected to match the drive type (IDE or SATA). When you do the disc removal, you will see if the cables are loose. Be careful with static while opening the computer.
Then replace the drive with a new one, reformat and reinstall the OS or use the recovery disc to attempt to fix the boot problem.
I hope this helps.
Nov 26, 2010 | Computers & Internet
Dropped my laptop. It didn't shut down or anything it ran just fine. When I turned it on this morning it would not start and prompted me to do a system restore. Started that but it didn't complete because...
When you dropped it you will have caused the Hard drive arm to contact the surface of the hard drive, damaging it.
Unfortunatly, it looks like it damaged the Boot files, Its worth a try with the recovery disc, you may need a new hard drive if it fails with the recovery disc
Sep 05, 2010 | Gateway Computers & Internet
0xa0000002 acer aspire 5315 recovery after new hard drive. Replaced the hard drive. got the system and recovery discs. system disc asks for language, then kicks out and asks for recovery. recovery disk...
make sure disc is clean wash gently with warm soapy water going from middle to outer edge then dry with soft cloth going from middle to outer edge make sure cdrom is set to boot first then put RECOVERY DISC in first when finished put system disc in.
hope this helps.
Apr 28, 2010 | Acer Aspire 5315 Notebook
I was wiping the hard drive when the laptop
Please come back to us with the exact error if you get any.
However, how you are performing recovery. Using recovery manager or recovery discs?
If you are using recovery manager, please perform hard drive self test and check with the result.
Hard drive self test steps:
1. Turn Off the notebook.
2. Turn ON the notebook and keep tapping F10 key
3. Once you are in BIOS, navigate to tools/diagnostics tab with the help of left and right arrow key.
4. You will find Primary HDD self test or HDD self test.
5. With the help of up and down arrow key select the respective test and hit enter.
6. Short test will take only 4-5 minutes. However, long test may take 40-60 minutes.
If the hard drive is fine, try to perform recovery using recovery discs....
If still the problem exists try with different discs.
If the hard drive fails replace the hard drive.
Hope this will work for you!!!!!!!!!!!!!!!111
Mar 17, 2010 | HP Compaq Presario V2000 Notebook
Hey
Hi, have you tried reinstalling using the recovery partition?
When the Vaio boots up, start tapping F10 several times.When you see a screen:"Edit boot options", hit the Enter button on the keyboard to load the Recovery Partition. On the menu select:"Compete system restore", then on the right hand side select Start. If you are offered to do Hardware Diagnostics or Restore C:drive first, select the Skip option at the bottom and select Next.Follow the instructions to start the recovery. It takes two hours, so make sure the power adaptor is connected.
If you have formatted your hard drive or deleted the recovery partition, you have to contact Sony to get a set of recovery discs. They will probably charge you, so if you have a friend with the exactly same Vaio, use his recovery discs.
Oct 20, 2009 | Sony VAIO Notebook
How to get a hard drive work again wen it been wiped
boot to the disc and follow the onscreen instructions, good luck!
Sep 29, 2008 | HP Compaq 6720s PC Notebook
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
