Question about Unotron (CS5100KR-B) Keyboard and Mouse
Unotron optical mouse under Vsta HPrm !
Can't get the Unotron mouse to work on a USB-HID port ? Running Vista HPremium. My resources are exhausted... Tried everything.., deleting it, re-boot, dis- & connect, to no avail...
Get a err report that 'driver' "might" be an .inf file for W95 or later although the 'pad' or rf rcvr shows activty can't get the devivce installed, had hoped that Visa SP1 would solve this, but no.... Its the C5100 for mouse & keyboard..
Any ideas, or just follow my impulse after last night &this morning..., buy another one !?! Not Unotron... :-)
Anthony.
The Unotron CS5100 range was discontinued some 3 - 4 years ago and replaced with the WS5100 so I am guessing that the one you have would not support Vista.
Have you tried contacting the place you bought it from, maybe they will switch it for you?
Jon
Posted on Jul 22, 2008
Jon
Jon
How to install e source 2.4 Ghz wireless optical mouse
plug in the receiver in a USB port. The mouse will have a button to push to synch to the USB adaptor.. Once it find it, Wilndows will install drivers and then good to go.. It will most likely show as a HID device when you are all done.. be sure you have good batteries when you do that.
Jan 03, 2015 | Optical Mouse Computers & Internet
How to move the mouse cursor with the keyboard in Windows XP?
  1. Click Start, Settings, Control Panel.
  2. Within the Control Panel open Accessibility Options or Ease of Access
  3. Click the Mouse tab.
  4. Check the "Use Mouse Keys" check box.
  5. If you wish to increase the speed or change any other settings, click on the Settings button.
  6. Click Apply and then close out of the box.
After performing the above steps you will be able to used the numeric keypad as a mouse moving up, down, left, right, and all the diagonals. In addition, you may also use the center "5" key as a left click.
Mar 24, 2011 | Unotron S5100KG Keyboard
When i turn my compter on to re-download windows 2000 it says keyboard error but wont read the d: drive. but the keyboard works except my f keys
Since windows 2000 is quite old now, I suggest using a PS2 interface keyboard USB may work.
Also your keyboard may have a F-Lock key, make sure its pressed when you boot up.
Oct 12, 2009 | Unotron S5100KG Keyboard
My keyboad is not on
behind your computer there are two ps-2 connectors, one is intended for mouse, the other is for keyboard.
check that you have connected your keyboard to the correct connector.
Jul 12, 2009 | Unotron S5100KG Keyboard
Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
I fixed an MS wireless mouse that was not responding by pressing the button on the receiver while it was connected to a USB port & then pressing the button on the mouse. Worked fine after that.
Dec 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Wireless Optical mouse - C5100M
Hello patches23,
Try the following procedure:
1. Go to your device manager. START>CONTROL PANEL>SYSTEM (If using XP, make sure you have chosen 'classic view' from the left side panel)>click on the 'Hardware' tab and you should see DEVICE MANAGER. Click this button.
2. Find the entry MICE AND OTHER POINTING DEVICES and click on the (+) sign next to it. Now you should see your mouse or just “HID compliant mouse” listed there. Double click this.
3. In the box that pops up, choose the "Driver" tab.
4. Click the button that says 'Uninstall Driver'.
5. Once this is done, right click on the MICE AND OTHER POINTING DEVICES entry again and from the menu chose "Scan for hardware changes" to reinstall or upgrade the driver.
6. On the 'General Properties' tab of the device, click 'Troubleshoot' to start the Troubleshooting Wizard and follow the on-screen instructions.
Hopefully, this should resolve the problem..
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 24, 2008 | Unotron (CS5100KR-B) Keyboard and Mouse
Boot problem
you need to do the following :
1- get yourself a PS2 keyboard
2- go to windows and install the S5100K-G keyboard driver
3- reboot the computer and go to the BIOS settings and make sure to enable the USB keyboard and mouse feature
4- shutdown the pc .. remove the PS2 keyboard and plug the S5100K-G keyboard then reboot
this should solve the problem
Dec 29, 2007 | Unotron S5100KG Keyboard
Belkin Optical Mouse
in control panel device manager, select the device and attempt to re-install the driver from a list of compatible drivers - select HID Compatible Mouse as opposed to USB Browser Mouse
Oct 31, 2007 | Belkin F8E836-USB-MOB Mouse
USB optical wheel mouse not detected by XP
Hi, You can try to: Right click on "My Computer", click on Properties, click on the Hardware tab, click on the Device Manager Button, expand your Mice and other pointing devices. verify that you 2 entries. One is the Sony builtin (Alps in my Vaio) and a HID-compliant mouse. The latter is your external optical wheel mouse. Make sure it does not have any red or yellow mark. Double click on the HID and verify that the next window says "This device is working properly." If not follow on screen instructions to enable or activate. Hope this be of some help. Good luck and pls post again how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | Logitech Wheel Mouse Optical
Unotron (CS5100KR-B) Keyboard and Mouse Logo
73 people viewed this question
Top Unotron Computers & Internet Experts
David Payne
David Payne
Are you an Unotron Computer and Internet Expert? Answer questions, earn points and help others
