Question about NetGear WGR614 Wireless Router
My netgear router stopped working after power failure. now led's brink on then off every 30 seconds or so. is it fried?
  • mrginc196 Aug 27, 2010
    if you mean reset using the slot at the back of the router, yes i did. same problem each time. also with turning power off/on.
  • Doug Olmstead
    Doug Olmstead Aug 27, 2010
    SLOT ???? should be a little hole - you would fit a paper clip into it.
    My std practice is to power off, use paper clip in hole turn on router - hold PC for 10 sec that should default router.
    once defaulted use MS- EI on you pc to talk to router on enter on your address bar 192.168.1.1 (most common DHCP address)
  • 104 Answers
Sounds that way - but have you tried to factory default the Router ?
Posted on Aug 26, 2010
Wnr834bv2 power light is sometimes on in amber, then blinking green and I keep losing connection
Try resetting and then reconfigure the router.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 11, 2012 | NetGear WNR834B RangeMax NEXT Wireless-N...
Firmware faild
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Feb 05, 2012 | NetGear MBR624GU Wireless Router
Wireless not working - the wireless light on the front of the unit is not on...the wireless settings don;t seem to work...netgear's phone support only wanted to charge me!
Please reset the router and then reconfigure it. To reset the router follow the below steps:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
Please reconfigure the router by running router configuration wizard.
If the issue persists then you may go for free online support with netgear by visiting the below link: my.netgear.com
Oct 13, 2009 | NetGear ProSafe FVG318 (606449041668)...
Netgear not working after power failure
Netgears are NOTORIOUS for this. If a hard reset didn't fix it, the one where you hold the red button down for like 30 seconds then it is gone. I have replaced SO MANY of these. The first thing that went on them was the wireless and they did have tons of complaints on this at one time as well.
Get a Linksys rounter, I have hardly EVER had any problems with them and they are now owned by Cisco, even better.
Oct 04, 2009 | NetGear WGR614 Wireless Router
My netgear do not power up
Please check if the power supply is connected properly to the router. Perform the steps below to reset the router:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
Check if the router powers up. If the issue persists then please get the router replaced from your reseller, as it seems to be a hardware failure.
Let me know if you need any further help.
Sep 24, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Test light does not stop flashing
Hi Michael,
If the router has test light continously flashing then tha indicates hardware failure with the router. Try resetting the router using steps below:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. Press it and hold it from 30 seconds and after 30 seconds without releasing the reset button take out the power cable from the router and wait for 20 seconds. After 20 seconds, without releasing the reset button plug the power cable back to the router and keep holding the reset button for another 30 seconds. Now, release the button and take out the power cable wait for 5 seconds then plug it back.
If the issue persists, then it is time for you to purchase a new router.
Rate it, if it helps.
Jun 26, 2009 | NetGear MR314 802.11b
Wrpn824v2 router keeps restting
This seems to be failure with the router hardware. Reset the router using steps below:
If the issue persists, then upgrade the firmware on the router by downloading the firmware from the link below:
http://kb.netgear.com/app/answers/detail/a_id/1222
If the issue still exists then it is time for you to either replace or purchase a new router.
Jun 26, 2009 | NetGear DG834G Router
No lights on except power light.
The firmware has been messed up. DDWRT might be incompatible with your router. I would highly recommend to reload the factory firmware or the latest firmware from Netgear's website. Loading 3rd party firmware will void the warranty of your device.
May 09, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
What hould be done to the software dwnloaded from netgear 4 route
You don't need a CD to configure your Netgear wireless router.
Just connect a network cable to your computer's 10baseT port and the plug the other end of the cable into the Netgear's 10baseT port.
Assuming your network card driver has been installed, configured and working, boot up your computer, and start your browser and enter this address http://192.168.0.1 Then enter the
user login = admin
password = admin
This enters you into the various configuration pages.
If you have changed the login and password and don't remember them, then you can reset the router to the factory defaults by the following steps.
Power off the Netgear, press and hold the reset button (you need a sharp pointer) on the back of the router, then power up the Netgear router, wait seveal seconds until the LEDs stop flashing, then release the reset button.
Dec 30, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
NEtgear RP614 cannot connect after a electricity shortage in our home :(
How is it not working? You get limited or no connectivity or it isn't functioning at all. Firstly, let's do a power cycle. Push the reset button for 5 seconds, unplug for 45 seconds, and reset 5 seconds, and unplug for 45 seconds. If that doesn't work try a hard reset. Alright, it's time to do a hard reset, this will rest all your passwords, Take a Pen or a pin, push the pin the the reset hole for 45 seconds, Uplug the modem for 1 minute, reset hole for 30 seconds, unplug for 30 seconds, and it should be hard resetted also power cycle.
Aug 25, 2007 | NetGear RP614 Router
NetGear WGR614 Wireless Router Logo
145 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
