Question about ASUS X83Vm-X1 Notebook
When I start up the computer it only goes to the Asus black screen and no farther. I put in the recovery disc but nothing happens. I can get into bios but not sure what to do once I get there. Help
Remove your battery completely, plug the AC cord in and try a reboot ;)
(If you leave your battery charger plugged in on a fully charged battery it may cause a voltage issue preventing your Graphics card or other things to start.)
Posted on Dec 23, 2010
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
I have an asus u52f or also known as the u53f with the windows 7 version i caught a virus n did not have the recovery disc after i ordered from asus n loaded the disc once i cam to the utilities n drivers...
Why didn't you just get rid of the virus which is the easy solution? Or you could have done a System Restore to a restore point (date and time) before you caught the virus.
Unfortunately most times those Recovery Discs don't work. The best Recovery Disk that works is the one the manufacturer puts on your hard drive.
Have you checked your hard drive to see if there is a Recovery Partition on it?
See if you can run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 28, 2012 | ASUS U52F-BBL9 Laptop
My emachine laptop has a virus. When you turn it on it goes to black screen with the option to start recovery mangement or start windows.When pressing either,it goes to black screen for a little bit then...
You may have files that you want to keep that you saved on your hard drive, but if you haven't backed them up then you will have to lose them because the only thing you can do to fix this is use the factory recovery disk which will wipe your hard drive clean.Just put the disc into the disc tray and you should get an option to start the recovery disc when you turn on the computer, it will tell you to press a key to start it which might be f3 or something different, I'm am not sure what key but when you have done that you should be able to start the recovery and wipe the hard drive clean and it should solve your problem
Oct 29, 2011 | E-Machines eMachines Desktop PC
I want to reboot my entire system so it starts from scratch, how do I do this?
If your system does have a recovery partition (typically says press f11 for recovery during boot if you have one) Reboot the pc, press f11 during the asus screen. The system restore utility will guide you through the rest.
If your system does not have a recovery partition
Take your system restore or operating system disc, Put it in the cdrom, reboot the computer.
When your pc starts back up (during the asus logo screen) During this screen there is usually a key sequence you can press to pop up the alternate boot menu. Typically the key is esc, f8 or f10. If one of those is right it will bring up a second menu asking what to boot from, select your cdrom. The cd will boot and your system restore disc will guide you through the rest..
Aug 28, 2011 | ASUS Computers & Internet
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on
the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire One PC Notebook
The problem of my hp pavilion dv5 is this, i want my laptop to be back on its original state so i tried system restore. i have my recovery discs aside from the built-in recovery partition. i inserted the...
You have formatted the hard drive (containing Boot Manager) using recovery disk 1.
That's why the error message.
Just insert disk 1 again.
Shut down the computer (press & hold the power button for a minute).
Restart.
Follow the instructions that come up.
If it doesn't help, reseat the hard drive. (open the back cover, take out hard drive, reconnect it)
Also you may go to BIOS (tap F1 while booting) and set the cd-drive as the first boot device.
Hope it helps.
Nov 06, 2010 | HP Pavilion dv5-1000us Notebook PC
Ran the Tshibery disk recovery disk. Completed and
Complete the recovery again but leave the discs in the computer. That way if the computer needs some files while rebooting it will take them off the cd....if not it will load and that will be the end of that. Just remember when you boot the computer for the first time to initiate the recovery, when it says to boot from cd touch any key...that is only done one time when you first initiate the recovery...after that do not touch any key if it says that...just let windows boot on it own. Once windows boots on its own, then you can take the recovery disc out and put it away.
Sep 07, 2009 | Toshiba Satellite A60 Notebook
ASUS X83Vm-X1 Notebook Logo
173 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
