Question about Goldstar Dehumidifiers
Model DH305T7. Blower fan bearings overheating/smoking
  • Goldstar Master
  • 43,501 Answers
the bearing have siezed up on the fan... some WD-40 and then some oil may get it going agian...
heatman101
Posted on Aug 29, 2010
I have a DH504EL. Should the fan run constantly? It hums, so I know the motor is running, but the fan isn't moving>
if the fan is simply humming but not turning over take the back cover off and make sure the blower piece is free turning. i used to have a dehumidifier(goldstar similar model long sold though) it had a bad thermal fuse in the fan motor but compressor worked perfect. bolt is i think 10mm and i had to peel the tape off of the motor windings to get at the fuse. soldered new one in(p/o gave me new fuse and 10 bucks to get it out of his hair what a deal:) ) and retaped the windings. also the felt bearings may be loose but i just lubed the front and back bearing housings well with syn-lube(valvoline for brakes) and reassembled. baby oil works wonders so does vasoline but due to heat that trick does not last long before making a racket and leaves a **** on the assemblies underneath(mess) so try the high temp lube or any moly based brake lube
Sep 12, 2011 | Goldstar DH504EL Dehumidifier
Compressor seems to be overheating although top is cool. Continues to run but doesn't collect water. Fan is working. Can't locate model number.
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
May 22, 2011 | Kenmore 54501 Dehumidifier
My glodstar DH305T7 dehumidifier wont stay on. Clicks on for a second then turns right off. Now it won't even turn on. There is over 70% humidity in my basement. Only 1 year old.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 17, 2010 | Goldstar DH304 Dehumidifier
Blower motor quit
u should have a number on the unit to call if not call the place it was purchased and see if they can get u in touch with someone who can help but that should definitely be a warranty part
Feb 23, 2010 | Haier HD656E Dehumidifier
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Blower fan is seized Kenmore 54501 Dehumidifier?
If the blower motor is siezed up, then you need to replace the motor.
You can have new bearings put in it, but by the time you get thru it will cost you about the same as a new motor and you won't have any warranty on the old motor, you will have at least a one year warranty on the new one.
Aug 09, 2009 | Kenmore 54501 Dehumidifier
Furnace/air cond. blower motor is smoking
I recently installed a horizontal gas furnace. All the electrical and gas supply was done correctly for sure, but upon the trial run, some smoke was coming out the supply lines into the house. I used some flex duct tape to seal all ductwork for air leaks. I also used some inside the first box coming off the heat exchangers to seal the inside of the box for leaks. Could the tape be burning because its to close to the heat exchangers and smoking or is it because its because its brand new and the heat exchanges have to burn a while? Please help
Jun 25, 2009 | Dehumidifiers
Goldstar dehumidifier dh305t7
The PDF file of the owners manual (35 pages, in more than one language) is over 8000 kb. This site seems to limit posts to 150 kb. It does not show an exploded parts diagram either. The manufacturer likes to use djvu files which download faster, but are not supported by "Fixya". I don't know what parts you are calling the interior panel connectors. Although we cannot ask for email addresses, I've seen some people post some.,....
Possiblly try: http://www.goldstarappliances.com
Sep 13, 2008 | Goldstar DH504EL Dehumidifier
Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory parts.com. Phone number 1-800-955-7075. $44.95 + shipping.
Gene
Feb 05, 2008 | Fedders A7DH65B2A Dehumidifier
Dehumidifiers Logo
79 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
