Question about Xerox 8830 Copier
How do I reset the fuser oil count on my Xerox 8830?
    New Friend:
  • 51 Answers
10-30
Posted on Dec 12, 2010
How do I fix a fuser error in a Xerox Work Center 4250 printer?
Hello, my name is Steve.
Keep in-mind that you still need to "Reset" the fuser's Image count.
Resetting this will start the process from "0".
Hope this helps,Steve
Aug 18, 2015 | Xerox Office Equipment & Supplies
7120 copier. Why is there a recurrent 'replace fuser' message?
The fuser's page count has been depleted. At 100K prints the machine declares the Replace Fuser message because it is almost worn out.
May 11, 2012 | Xerox Office Equipment & Supplies
Out of fuser oil. Xerox 8830. No one seems to carry this in supplies. Where can this be ordered?
Hello and welcome to FixYa.Com
Fuser Oil can be ordered directly from Xerox. It is Part # 008R00079 and you can get it from this website: http://na-supplies.xerox.com/product-resources/008R00079/enca.html
Feb 28, 2011 | Office Equipment & Supplies
Xerox 8830 LL-60 Checksum fault
enter in diag mode and press 03-60 reset the nvm
Nov 01, 2010 | Xerox 8830 Copier
How do you reset an Error code LL-05 on a Xerox 8830
enter in diagonistic mode by pressing 0 then on then press10-30 then on andoff
Oct 19, 2010 | Xerox 8830 Copier
Getting code H 4 -- won't reset. Any idea what this code means?
Heater Code , fuser unit/fixing unit error. Needs fixing/fusing unit replaced.
Jun 10, 2010 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL43 error
An LL43 is a fuser temperature error.
When you first turn on the printer it should display printer warming up and after a little while display the LL43. If the fuser is still cold then you probably blew the thermal fuse and it will need to be replaced.
Oct 01, 2009 | Xerox 8830 Copier
Where to put fuser oil in a xerox 5624 copier
I don't believe this machine uses Fuser oil. I bet it was picked up from a sight that had other machines and the oil was just put inside the machine as it was being wheeled away.
Sep 09, 2009 | Xerox 8830 Copier
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
Oct 13, 2008 | Xerox Phaser 4500 Printer
XEROX 7300
Sounds like you have had a fuser roll failure.
Could be either the heat or pressure roll failure from your description.
That is an easy replacement. You can call 1-800-835-6100 and order one. It is on the left side of the machine, The area that is very hot. It has 2 thumb screws to remove and replace it. Only issue would be, the fuser has a replacement count on it that needs the proper laptop hooked up to it to reset the count. Although it will not fail to run without the count reset, once the fuser count reaches 100,000 images in the counter, it will shut the machine down until it is reset.
Mar 18, 2008 | Xerox Phaser 7300DN Laser Printer
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
