Question about kawasaki Full Suspension Mountain Bike Men
1995 kawasaki 750 jet ski overheats when going fast
    President:
  • 1,978 Answers
Check your plug color. You may be having a high speed mixture problem. Is your ski spitting water out the tiny hole on the side? You should try flushing the engine, you could have a motor full of sand if you beach the craft but do not wash the sand out of the back before starting. Also inspect the engine water tubes for cracks. From the hull to the motor and from the hull to the jet pump.
Posted on Sep 03, 2010
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
damaged impellor or housing , grabbing air !
Dec 19, 2013 | WSM 1995-1997 Kawasaki 750 Zxi Cdi...
Kawasaki watercraft
compression check , 100psi or more ! battery and connections good ?
Jul 06, 2013 | WSM 1995-1997 Kawasaki Sxi 750 Cc Jet Ski...
Need a service manual for 1995 Kawasaki ST jet ski
You might want to post this question in a different section. This is the computer games section.
Aug 13, 2012 | Video Game Consoles & Games
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
Where do you read the mileage on a 1996 Kawasaki 750 sts jet ski?
I hate to tell you this but we go by hrs. the motor has ran for if theres not a hr.meter on the jet-ski you well need to istemate on how many hrs.it has ran.If you think maybe the water impeller needs to be replace,it won't hurt.better to replace then be stuck.
Jun 17, 2010 | kawasaki Full Suspension Mountain Bike Men
I have a 1995 kawasaki zxi the bolts on top of
The numbers on the head are the torque pattern/order. Two stroke motors generally use a torque value of 18 to 22 foot pounds on the head bolts/nuts.
Feb 01, 2010 | Encore Software Kawasaki Jet Ski...
Removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Jun 15, 2009 | Boating
kawasaki Full Suspension Mountain Bike Men Logo
512 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
