Question about Kenmore Dishwashers
Dishes are not getting clean - Kenmore Dishwashers
  • Kenmore Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
It doesn't wash the dishes well, leaves dirt and doesn't melt the detergent
Dishwasher Not Cleaning Dishes - The Family Handyman
www.familyhandyman.com > Skills > Appliance Repair
When your dishwasher doesn't clean well, fix it yourself following these simple steps and avoid the expensive professional service call. A simple cleaning often ...
Why Doesn't My Dishwasher Actually Clean My Dishes ...
dishwashers.reviewed.com/.../why-doesnt-my-dishwasher-actually-clean-...
Feb 26, 2015 - My dishwasher is supposed to wash dishes, right? So what are all these ... The good news is that filters are incredibly easy to clean. The little ...
What to Do When the Dishwasher Won't Clean - YouTube
? 8:27
https://www.youtube.com/watch?v=aZojUCnQifs
Sep 21, 2012 - Uploaded by doityourselfstan
Dishes aren't getting clean in your dishwasher? The problem ...Whirlpool, Maytag, Sears dishwasher Repair & diagnostic - Not cleaning well ...
Jan 01, 2016 | Dishwashers
Why are dishes clean but still seem to be greasy?
hi,you can take off the washers that spin and clean them ( sometimes the holes get blocked on them ) also make sure you have salt in the machine and rinse aid
Apr 24, 2015 | Dishwashers
Any ideas as to why dishes do not come clean?
Their cold be a couple of reasons. Are your dishes stacked too close together inhibiting the water from getting to the dishes? Are you putting in enough soap to get the job done? How dirty are the dishes and how long has the food dried on the dishes? when I have a lot of dishes I always put the dishwasher on high temp to make sure the dishes get clean!
Mar 07, 2015 | Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
Dishes not getting clean dish tab not disolving
Check to see if your water is 140 degrees.
Is the cup opening to release the tablet?
Nov 28, 2009 | KitchenAid Dishwashers
Clean dish
'tdulany's remedy for cleaning the dish on the Presto Heat Dish probably works well, but how do you get past the grill covering the dish in order to clean it?
Nov 26, 2009 | Presto HeatDish Compact Heater
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Dish washer not getting the plates clean.
WHAT KIND OF DETERGENT ARE YOU USING?
Jan 08, 2009 | Dishwashers
Presto Heat Dish
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Feb 07, 2008 | Presto HeatDish Compact Heater
Dishwashers Logo
37 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
