Question about DBX DriveRack 480 Processing Unit Home Equalizer
I am getting "Network Not Detected" Work In Offline Mode.
How do i change my phone from offline to online??
Hi.
Your phone likely to be offline mode automatically when it might not have detected your SIM Card. the Sim may not have been place in well. off your phone and check the SIM if it was properly inserted. on it again and your nokia cell phone will ask you if you still want to continue in offline mode? click no. and the offline settings will change.
Hope this solution works for you.
May 18, 2011 | Nokia 6790 Surge Cell Phone
Since i switch on my fone is on offline mode
For this issue, you may need to manually search for a network if there's a sim card inside it. Or go to the network options on that phone turn off offline mode. I hope this helps a bit
Mar 09, 2011 | Cell Phones
My NokiaN70 is in the offline mode and I cant get to be in the online mode. On start up it asks continue using the phone in offline mode, when I press the No button it does not respond but continues to...
Offline mode means the sim you have inserted was not detected by your phone.Firstly clean the Sim Card slot(case)and check the connector.If the problem still persist contact nearest mobile repairing center.
Good luck
Visit Again...........Fixya.com
Aug 15, 2010 | Nokia N70 Cellular Phone
The mode will not change, itried reseting the pho...
do check your sim card that it is properly inserted or not...sometimes the sim card not properly inserted so the mode can'nt be changed
May 20, 2010 | Nokia E51 Cellular Phone
My HP Photosmart C4580 wireless printer will print when the computer is plugged into the printer. However when disconnected it will not print and will say that the printer is offline. How do I make it...
you gotta go into the printers folder in control panel and and right click on you printer icon and then select use printer online ,just to check if you printer has been connected wirelessly properly or not insert the cd and click on add a device and then try to install your printer in the wireless network if you printer is detected then install it and complete the installation ,it means that your printer was not installed but only configured to work on the wireless network thats why you keep getting the printer offline
Jun 25, 2009 | HP Photosmart C4580 All-in-One InkJet...
Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
May 13, 2009 | Kyocera Copystar CS-1820 Black and White...
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Nokia n95 is saying offline
You've probably selected the "offline" mode on your phone. To get the phone to access the network again, go to the idle mode of your phone, then press the power switch of your phone ONCE, then select any profile.
Ex: meeting
It'll then display a message like " phone is currently in offline mod. Change profile to access network?"
Select "yes"
That should fix your problem
Let me know how it goes.
johnny
Sep 16, 2008 | Nokia N95 Cellular Phone
My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Apr 12, 2008 | Nokia 3250 Cellular Phone
DBX DriveRack 480 Processing Unit Home Equalizer Logo
Top DBX Audio Players & Recorders Experts
Philip Rowney
Philip Rowney
Vito Vacirca Jr.
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
