Question about GPS
My Lowrance Freedommaps card will not work in my Lowrance h20 gps
  • 2,272 Answers
If the car is not getting detected,then the card may have got corrupted.If the card is new and under warranty then get it replaced by the Lowrance service center .at-least they will get it confirmed if card is working or got corrupted.In many cases it has been seen that card gets corrupted.Keep updated.Thanks.
Posted on Aug 26, 2010
If I get a new Lowrance GPS, can I use my SD card from my ifinder Hunt in the new device and use all my saved points?
First use "add gps" and add the original unit and the H20
use "receive from gps" to call in the original waypoint file from your sd card
use "send to gps" to save the new waypoint file to the sd card
remember that the original gps file may contain more waypoints than the H20 can hold so you may have to delete some waypoints from the file while in EasyGPS
if this is not clear enough, let me know and I will try again. I use the program all the time.
I just realized I left something out. EASYgps does not like the Lowrance HDS File version so an extra step is required if you are transferring files from an HDS to an IFinder. Save your HDS waypoints as Version 3 to the SD card and EASYgps will accept them
Oct 21, 2013 | Lowrance iFINDER GPS
The Lowrance 3500C has a 1 GB capability. Does that mean I must purchase a 1 GB SD card for it? Can't find anything smaller than a 2 GB SD card, but will a 2 GB card cause problems?
No, this means the internal memory size is 1 GB. If this unit accepts SD cards, you can increase the map capacity. 2GB SD cards should work properly in the unit.
Nov 01, 2010 | Lowrance GlobalMap 3500C GPS Receiver
Need a fully working Lowrance 250C GPS SD card or a copy of the same.
I have had a similar problem and founf this site where you can get a new card that will work for your GPS. Info, pasted below:
The Nextar GPS-MAP09SDC SD card with updated navigational maps and information has a MSRP of $69.99. Please visitwww.nextar.com to purchase the map upgrades and for more information on upgrading your maps.
Apr 18, 2010 | Lowrance iWAY 250C GPS Receiver
Just bought at auction. No manuel.
My apologies. I see now that you have an iWay 250C. Here is the manual as found on the Lowrance website.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/iWAY250c-manual_0160-201_080706.pdf
Aug 06, 2009 | Lowrance iWAY 250C GPS Receiver
GPS Does not work
If you have a memory card inserted, remove it...if the problem goes away, try replacing that card. If the problem occurs with any card then...
Try installing the latest update from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
even if you already had the latest...try installing it again.
If the problem occurs with any card, and after updating or attempting to update, there is a probably a malfunction with the XOG and it will need to be repaired/replaced. The Lowrance contact by phone is 800-324-1356 and go to http://www.lowrance.com/en/Support/Product-Support/Contact/ to email them.
Apr 11, 2009 | Lowrance XOG GPS Receiver
Lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Mar 08, 2009 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance 100 works lowrance 500 dosen't [dropped] swap chip?
You cannot use a chip from the AirMap 500 in an AirMap 100. The AirMap 100 is not compatible with the mapping used with the AirMap 500 and the AirMap 100 does not have a memory card slot.
I suggest you use the AirMap 100 while you think about getting the AirMap 2000 or some other newer aviation GPS unit.
Jan 04, 2009 | Lowrance 5300C GPS Receiver
Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Jul 02, 2008 | Lowrance LCX-27C GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
