329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
    Novelist:
  • 120 Answers
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Posted on Aug 29, 2010
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
I have a Rinnai RCE-329H gas heater that keeps turning off.
Check..for gas pressure creep.....2 lb sys....big problem...change to green hat....pig tail line.....rinnai gas valve problem being fixed....
May 31, 2012 | Heating & Cooling
Rinnai rce 329h manual
Hi, For anyone needing a User Manual for a Rinnai 329H gas heater, I just downloaded a free one from manuals.com. All you have to do is supply your first name & email address and it displays instantly. Hope this helps, Ali
Apr 13, 2012 | Heating & Cooling
Rinnai 551FT Hi I have just got this model
On the data plate on the heater it will say NG for nat gas or LP for bottle gas
Jun 05, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I want to buy a portable generator?
most,if not all, genys,produce enough power to run several freezers,you only need about 500 watts max for one.....touble is, you need a self start generator so when temp low it starts and correct temp it stops,sort that problem and you save a fortune in gas.....its cheaper to buy a gas unit and bottled gas.
Jun 29, 2010 | Frigidaire PLRS267ZAB Side by Side...
Is there any difference in bottle gas heater and natural gas heater
by bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
Apr 23, 2010 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Sep 10, 2008 | Coleman Powermate Premium Plus 6250W...
Heating & Cooling Logo
278 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
