Question about Plumbing
I removed the metal and plastic retainers, but I cannot lift the spout off. The faucet leaks at the junction. I have replacement "O" rings but how do I remove the spout from this point?
  • Walter Pretzel
    Walter Pretzel Oct 25, 2015
    After removing the metal and plastic retainers, my spout came off just as Dplumber described, I never turned the water off to the faucet, so a little water pressure caused the spout to come off with only a little water on the sink. I couldn't get the Delta parts but 2 generic O rings, 1-1/8 x 7/8 x 1/8 worked fine.
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
You are doing a great job so far. The reason for the trouble is that at least on of the O-rings is still in good shape and holding the spout securely. to overcome the O-rings tension you need to rotate the spout back and forth while lifting it straight up. Try not to lean the spout from side to side, you will create for tension. This is not always easy to do, just keep at it. If you turn the water off to the faucet and open the faucet's handle(s), you sometimes get relief from the back-pressure. Remember to lubricate the new O-rings with plumber's waterproof silicone grease before reinstalling.
Posted on Aug 26, 2010
Price Pfister Marielle, 26 series, leaks around the top of the spout body when water is turned on. How do I take it apart and fix the leak?
1 under the sink turn off both water supplies
2 disconnect the supply lines at the on/off valve EZer than at faucet
3 under sink unscrew the retaining nut(s)
4 on top wiggle or pry the faucet and lift up and remove.
5 know you can replace the spout and don't forget the new O ring that's why it leaks anyway. you really just need the new washer O ring .
6 Reinstall check for leaks
7 caulk around faucet.
Hope this helps Mike
May 31, 2018 | Price Pfister Plumbing
Tip
Ball-Type Single Lever Faucets
BALL-TYPE SINGLE-LEVER FAUCETS
  • The single-handle faucet with a ball inside to control both hot and cold water may either leak at the spigot or at the handle. A handle leak is usually caused by improper adjusting-ring tension. Simply adjust the tension to stop the leak. Leaks at the handle can also result from a worn cam gasket. Dripping from the spigot is usually caused by worn spring-loaded, soft rubber seat assemblies.
  • Parts for ball-type faucets are available in kits. Get the spring/seats kit for spigot leaks, or the complete kit for handle leaks. It may be advisable to use the complete kit to replace all working parts of the faucet at the same time. In any case, you'll need a kit containing the spanner/hex wrench for removing the handle (hex end) and turning the adjusting ring (spanner end).
  • Without turning the water off, loosen the handle set screw. Slide the handle from its stem.
  • For a handle leak, try using the spanner wrench to tighten the adjusting collar. Tighten it by turning the wrench and collar clockwise until the faucet doesn't leak when it is turned on and off. If the adjustment is too loose, the faucet will leak. If you turn it too tight, the handle will be hard to move. When the adjusting ring cannot be turned with the wrench, it is corroded. At this point, you will need to remove the cap to free the adjusting ring. (See next step.) You must turn the water off before removing the cap! Apply penetrating oil to the threads, remove the ring and clean all parts before reassembling.
  • Install the seats. For faucet leaks at the spigot, you must install new rubber seats and springs. You must turn off the water to make this repair. Unscrew the chrome cap by turning it counterclockwise. If it won't turn easily, wrap electrical tape around the cap and turn it with pliers. The adjusting ring, which is threaded into the cap's center, will come off with it. For a seats/springs replacement, pull the ball up and out by its stem. The gasketed cam will come with it. Now you can locate the two rubber seats and springs inside the faucet body. Remove them with pliers or yours fingers and install the new ones. The springs go into the holes first, and the cupped sides of the seats fit over the springs.
  • Service the ball. If the ball is dirty or coated with scale, clean it or replace it with a new one. Both plastic and brass balls are available, but use a plastic one if your home has hard water.
  • Reassembly. Put the ball and cam back into the faucet with the slot in the side if the ball fitting over the pin in the faucet body. Then make sure the tab on the cam slips down into the notch in the body. Not aligning the tab and notch is the number one cause for a faucet leaking after it is repaired. Finally, screw on the cap and adjust the ring as described in Step 2. If a properly adjusted ball-type faucet leaks at the cap, the cam and gasket must be replaced.
  • Swing spouts. If a single-lever ball faucet leaks at the base, you should replace the O-rings. Remove the spout-retaining parts, as well as the spout. Wrap the spout-retaining nut with electrical tape to protect it, and remove the nut with a wrench or pliers by turning counterclockwise. Remove the spout by pulling it up and side-to-side. One or more O-rings should now be exposed. Take the O-rings to your hardware or home center store to get matching O-rings for replacement. Clean any scale that appears on the spout base, faucet body, and the inside of the swinging spout. Install the new O-rings and reverse the steps above to reassemble the faucet.
on Jan 16, 2010 | Plumbing
My kitchen sink sprayer is leaking when the faucet is on, but the sprayer is not engaged. How do you repair it?
It can be one of two things. It could be the spray divertor located on the post of the faucet. For a basic Moen Kitch faucet you must remove the handle. With older faucets simply pull up to slide off the hdle cap, unscrew the center screw that holds a black plastic retainer cap, to remove cap, disengage it by lifting handle. Now remove the metal, grooved retainer nut by unscrewing. You can now slide off the spout. You will see a white cylindrical ring which is wider at the base, and has two o-rings. This is the divertor.Slide it off. The part # is Moen 91192. Apply faucet grease or silicone grease to the o-rings exposed on the faucet post as well as on the inside of the new divertor. Slide the div. back on and reassemble in reverse order. If this doesn't work, just replace the sprayer head. Unscrew the head from the nut at the bottom of the head. You will find two gaskets. Remove them from the grooved plastic nipple and make note of which one goes on first. The plastic nipple has a lock ring, a "C" shaped piece of metal set in a groove on the nipple. Remove the ring using a small screw driver. This can be a little tricky. Do not damage the plastic, and don't lose the lock ring.. Now you can remove the bottom of the head. Replacements come in various styles and colors, so pick one suited to your tastes. Now reverse the process. and you have a new head. Good luck!
Sep 03, 2013 | Moen & One Handle Tub & Shower Faucet
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
I have an older American Standard kitchen faucet (installed around 1950) with a leaking spout. I have removed the spout, cleaned out all the old packing after removing the tempered steel split o-ring and...
If you have a payless cashways in your area they carry americanstd. faucets and plumbing fixtures.I think that some K-Mart and sears stores do also. Hope this helps you. Thanks
Dec 22, 2010 | American Standard 4275.550.002 ColonySoft...
Any tricks to lifting the spout off the base? I slid the collar up and removed the plastic retainer, but don't seem to be able to life the spout.
Run the hot water for a few minutes this will expand the spout and help loosen the seals. You may have to pull hard but it will come off. Use alittle silicone grease on the o-ring when reinstalling.
Jan 16, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Plumbing Logo
333 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
