Question about RTO Pit Bikes
My 125 loncin pit bike wont get spark and i already changed the ingnition coil...please help
danforddan1
  • 192 Answers
SOURCE: i have a pit bike 125 its not starting wot so ever
If you have spark them it must be gas. eather no gas or to much gas. Put it on chock, be sure the shut off valve is in on position.Now crank it over a few times , if it wont fire. Check the plug , is it wet or dry .If its wet then it may be flooded and needs to dry out and air out the cylinder.Try starting when dry. If its dry try putting a 1/2 oz of gas into the spark plug hole. replace the plug and turn it over . This will get them to fire up. Good luck DFD
Posted on Apr 22, 2009
  • 9 Answers
SOURCE: 125cc pit bike no spark need help at witts end.
remove the alternater cover and check all the wires are intact behind there
Posted on Oct 03, 2009
  • 5 Answers
SOURCE: My pit bike 125cc wont fire up
Try unpluging the cutouts.they are usally on 2-3 places on these bikes ,brakes,also check the fuse that is on the red wire comming off the battery it will be blown or end of fuse holder will be pushed in and not touching the fuse.
Posted on Jun 25, 2010
  • 7 Answers
SOURCE: My 49cc quad bike is new wont start have changed
Maybe re-check the gap between the coil and the flywheel? x2 business cards is a good gap for those.
Posted on Sep 06, 2010
  • 3 Answers
SOURCE: pit bike 125cc started but since i moved eclip on
put the clip back to middle or where it was and adjust up idle screw at carby. The lei 2 strokes do not start from new you can pull and play with choke but until you idle it up by adjusting screw on carby about 1/4 to 1/2 turn it will fire and run.
Posted on Nov 03, 2011
Where can I find an accurate diagram for a 48cc Loncin mini chopper
Hi, Toby for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
loncin mini chopper wiring diagram Google Search
Chinese ATV Wiring Diagrams for Loncin Engine Powered ATVs and Dirt Bikes...
LONCIN 48cc Mini Chopper engine PLEASE HELP
http://www.miniriders.com/tech-talk/29110-pit-bike-repair-parts-manuals-exploded-views.html
FS517 49cc Super Chopper parts ScooterParts4Less com
Jan 28, 2017 | Loncin Motorcycles
The coil on my 125 cc pit bike broke every time that I started the bike, I run the bike for a little while then go off killin the coil, I have tested two coil and both broke
Hi, Jose and the usual suspects are:
1. Wrong coil for service application.
2. Damaged or worn out spark plugs.
3. Spark plug gap too wide.
4. Damaged, leaking, worn out spark plug wires, boots, or center cap connectors check for spark leakage in the dark.
5. Excessive vibration due to the loose mounting bracket.
6. Faulty ground check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bad Stator Fix Don buy new stator for your engine Create battery op...
ELECTRONIC IGNITION
http://mypitbike.ru/downloads/ThumpstarServiceManual.pdf
http://mypitbike.ru/downloads/SSROwnersManual.pdf
Dec 03, 2016 | Pit Bike 125cc 4 Stroke Dirt Bike
There is no spark it is a 125 pit bike just bort a new cdi ther plenty compresion but no spark can you help
there are 2 things you can do
1. check the plug/coil connection
2. make all the coil wires are hooked up properly
3. buy a new coil
Mar 24, 2011 | Pit Cycling
Wont spark
i think its the coil
May 21, 2009 | Pit SSR 110CC Pro Beginner Bike
I have a pit bike 125 its not starting wot so ever got good spark but still not start
Apr 22, 2009 | RTO Pit Bikes
RTO Pit Bikes Logo
182 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
