Question about Whirlpool Duet GHW9150P Front Load Washer
Duet code f-01 is showing. - Whirlpool Duet GHW9150P Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F01 in your whirlpool duet sport indicates EEPROM error which means that a communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred. This error also occurs when the pump driver fails to activate and/or one of the main relays is not working. To resolve this issue leave the unit unplugged for 5-10 minutes so that if this was caused due to power surge it is cleared. Also check the CCU (central control unit), if bad you’ll have to replace it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
Maytag model MEDE500VPO what does the f 01 code mean?
Controller board malfunctioning.
Try looking at the video at
Duet Sport Dryer 2008 Error code 01
If repairs like this are not something you want to attempt, try calling a repairman, particularly if the dryer is under warranty.
Jan 04, 2012 | Dryers
Get the code F-01 on the whirlpool duet front loading washer, not sure what this code means
Click this link directly:--- http://mymoremoney.blogspot.com/2011/01/whirlpool-duet-ghw9150p-front-load.html --------------- In this there is instructions and procedure mentioned to resolve the issue. If any part checked out faulty then you can get it from www.repairclinic.com .----------- Thanks.Helpmech.
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When the machine on it showing f-01
Tilt the washer back and support it with wood blocks so you can remove the kick panel screws and get the tech sheet from inside.
F/01 is an EEPROM error on the CCU. A power glitch may cause this error; unplug washer or disconnect power for two minutes. If broken, then you'll need a new CCU-- not a rare event on this washer.
s there a link to the diagnostic test for the washer? I found the one for the dryer here:
http://fixitnow.com/wp/2007/06/19/whirlpool-duet-sport-dryer-diagnostics-and-fault-codes/
Jun 06, 2010 | Ariston Technologies AWD121WH
Flashing F
check out this link for the error codes u receive and how to resole it manually
http://www.applianceaid.com/duet_washer.html#duet
good luck thanks.
Oct 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-01 ERROR CODE ON WHIRLPOOL DUET SPORT HT
take the front panel off the bottom and the error code manual is inside. Mine says a ccu replacement for the F-01 code. Yours should be on warranty if it is brand new.
Jul 09, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
185 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
